need help with TYPE R 4 Lug Conversion
Old Dec 4, 2007 | 08:23 PM
i.got2!'s Avatar
i.got2!
Default need help with TYPE R 4 Lug Conversion
well my gsr needed so new shoes, so i decided to get it even better 4 Lug TYPE R Conversion I installed everything already but its time to get the brake fluid in, so it means BLEED the brakes i tryed bleeding them already but my brakes DIN"T work :........ im now thinking that my cylinder needs to be replaced
Old Dec 5, 2007 | 04:19 AM
Skelly_GSR's Avatar
Skelly_GSR
RB does men
Why the fuck would you go from 4 lug usdm gsr to 4 lug jdm itr?
Old Dec 5, 2007 | 07:29 AM
i.got2!'s Avatar
i.got2!
I like the wheels and I think that if some1 would ask me what year is it my body and wheels would answer 4 me PLUS I always see 5 lug Type R and not many 4lug Type R
Old Dec 5, 2007 | 07:54 AM
MC-14's Avatar
MC-14
Tri-man
Huh? Shouldn't the lug offset 4x100mm be the same for both. That's really stupid............
Old Dec 5, 2007 | 08:18 AM
i.got2!'s Avatar
i.got2!
Well no because its actially4 × 114
Old Dec 5, 2007 | 08:40 AM
Provocateur's Avatar
Provocateur
On permanent hiatus
Yes, the bolt pattern is 4 x 114.5 as opposed to 4 x 100.
If the brakes don't work after properly bleeding them, you have a leak somewhere. Determine where the leak is and you will find your problem.
Old Dec 5, 2007 | 12:59 PM
MC-14's Avatar
MC-14
Tri-man
Okay cool! I thought they would be the same if going to the 4 lug itr wheels.
Old Dec 5, 2007 | 08:00 PM
i.got2!'s Avatar
i.got2!
on the right spindle theres a cable the TYPE R has it on the Left Side Does Any1 know how to deal with that because i'm guessing to just leave it off or should a just swap the rotor and use the USDM arm with the Type R Rotor And Bolt pattern
