integra [1990 GS w/ starting problems]
Old Mar 18, 2006 | 09:04 AM
bigl90gs's Avatar
bigl90gs
Default integra [1990 GS w/ starting problems]
My 90 integra gs is having a similar problem to one ive read about on this site. When i picked it up it ran fine for about four hours, when i got to my street i stalled and would not start, im thinking its the distributor but not sure if i should replace it. when started the car runs great.
Old Mar 18, 2006 | 10:44 AM
94civicEX's Avatar
94civicEX
I got worms.
You check the battery connections and your battery life?
99 Integra GSR
06 TSX
duck squad member #00003
Old Mar 19, 2006 | 12:03 AM
Movies4Fun's Avatar
Movies4Fun
Check the alternator and belt tension.
Old Mar 19, 2006 | 08:31 AM
bigl90gs's Avatar
bigl90gs
Thanks Fellas
Old Mar 20, 2006 | 03:19 PM
bigl90gs's Avatar
bigl90gs
Default Damn
Somebody help me.My alternator is fine, doesnt seem to be any electrical problems. The car stutters a bit in some gears and the tachometer goes all over the place. I dont know what is wrong with my car. I wont start occasionally and im doubting it is th fuel pump.
Old Mar 20, 2006 | 07:45 PM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
< Threads Merged >
Since we're still talking about the same car, please use one thread for problem diagnosis and repair. Thank you.
Old Mar 21, 2006 | 05:44 AM
flybye's Avatar
flybye
I think I'm the one your refering to, I still havent figured it! I did have a problem starting the car about a week after geting it back, I have a FPR and it was turned up to about 90 psi, I turned it to 55-60 psi and its been fine with starting. The distributer is about 800 from the dealer so I hope our problems dont lead us to this point. hope this helps you a little.
Old Mar 21, 2006 | 08:40 AM
Kai's Avatar
Kai
Rotorphile.
Turn it down to 40-45psi. 60psi is too high, 90psi would brake sh*t.
Old Mar 23, 2006 | 07:15 AM
flybye's Avatar
flybye
would it really, thanks for leting me know. I went to a shop called IN LINE FOUR and they said i need a vtec controller because of my stage 2 blox cams,they said they make power from 6000 & up in the rpm's. I have a stock ecu, could this be the problem solver or no? any ideas?
