how do i put an h22 in a 94 integra
Old Feb 28, 2006 | 03:55 PM
mrproul's Avatar
mrproul
Default how do i put an h22 in a 94 integra
I just got an h22a and i have heard that you can use the b series axles, get a gsr wiring harness, and just get the motor mounts. that sounds to easy. if it that easy then i will have it in over the weekend, if not does anybody have any links for this setup.
thanks,
Mrproul
Old Feb 28, 2006 | 03:59 PM
Exadar's Avatar
Exadar
Be Quiet and Drive
check the hybrid forum
Old Feb 28, 2006 | 04:03 PM
dubcac's Avatar
dubcac
I
You'll need the mount kit. You'll need an accord/prelude shifter. You'll have to cut the floorboard to run the cable shift linkage. You'll have to remove the upper tranny mount from the passenger side frame rail. You'll need a prelude intermediate shaft. You'll need 90-93 integra axles, or custom axles...I'd recommend custom...HASport sells some for the swap.
Here's a list from HASport.
http://www.hasport.com/Tech/Installs...%20Integra.htm
Here's a mount install guide:
http://www.hasport.com/Tech/Installs/egh1.PDF
