IACV wiring question
Old Dec 5, 2005 | 09:55 AM
R_Squared's Avatar
R_Squared
LEVEL UP
Default IACV wiring question
Ok, the sensor that plugs into my IACV has become disconnected and now I need to solder/crimp/whatever to reattach it. My question is this: Which wires running from the sensor (blue or yellow) attaches to which wire? (If you look about 8 inches down the two wires you will see there are blue plastic things attached to the wires, one of which is wider than the other..this may help to determine which goes to which.) Please help! I will attach pics if necessary.
Old Dec 5, 2005 | 10:09 AM
R_Squared's Avatar
R_Squared
LEVEL UP
After looking at my repair manual I saw that the blue wire goes to the ECU wiring and the yellow wire goes to the PGM-FI main relay. This still doesn't clear up which wire I need to connect what to...Please help.
