Ingalls tork specs, bought used, no instructions
Hi, I bought my Ingalls kit for up front used without instructions and have been using them for about a month now with no problems except the bolt that goes up thru the top has been loosening because I don't know how hard to tork them down. I need the tork spec for the upper nut and the lower adjusting nut. The only problem I have had with the Ingalls kit is the upper arm hitting the inside fender lining, so I grinded alittle away, all is well now. Tork specs pls.
Oh , anyone else with Ingalls on a second gen teg remove the thin bridge that was on the original mount studs, I just removed it and have had no problems, alignment was dead on (camber wise). TIA
