**Brakes thread**
Old Mar 11, 2004 | 05:02 PM
b00gers's Avatar
b00gers
Default **Brakes thread**
I was curious to know what everyone's setup is, and their feedback on it.
can you guy post the type of:
Rotors
Pads (cost / dust / noise)
Fluid
and your feedback on them. im mainly curious about the ones that uses the OEM calipers, but if you have aftermarket ones, please share.
and since i didnt want to make a whole other thread, does anyone have the directions to swap the four rotors and pads and putting in NEW brake fluids on the integras. specially 1999 GS sedan.
thanks a lot. :thumbup:
Old Mar 11, 2004 | 05:12 PM
Epoch's Avatar
Epoch
CHRISTMASTIME IN IRAQ
OE
OE (Could grip better, almost nil dust and noise)
OE
Old Mar 11, 2004 | 06:12 PM
g2tegls's Avatar
g2tegls
MR, ftw
formerly on the teg:
4 Brembo blank rotors, about $20 a piece
AEM/Nissin front pads ($45), Raybestos rear ($20)
Valvoline high temp fluid
Also had speed bleeders :thumbup:
I'm not a pro here, I haven't had any other set up other than stock and this felt like much stronger braking power.
Old Mar 11, 2004 | 07:03 PM
LT's Avatar
LT
The deer had to die!
Rotors: replaced w/ OE
Pads: OE front (overpriced/low dust/no noise), Advanced Auto rears (very cheap/lots of dust/no noise)
Fluids: OE
Calipers: replace w/ OE
Old Mar 11, 2004 | 09:33 PM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
General rules:
- Slotted, drilled, or dimpled rotors are mostly for bling; plain replacements are fine
- Good pads in no particular order: AEM, Axxis/PBR MetalMaster, Axxis Ultimate, Hawk HPS, Porterfield R4S
- Stainless lines are a big thumbs up in improving feel
- Good fluids, again in no particular order: Ate Super Blue, Motul RBF600, Valvoline SynPower
If you go to bigger rotors or calipers, you will get bumped from SCCA Stock, Street Touring, or Street Prepared classes. (Figured I'd mention that since you might be doing that type of stuff)
Old Mar 11, 2004 | 10:09 PM
Nelson's Avatar
Nelson
Administrator
Front Rotors: Rotora Cross drilled and Slotted.
Front Pads: Rotora Ceramic Pads.
Fluid: ONLY ATE Super Blue.
Stainless Steel Lines.
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX
- SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
Old Mar 11, 2004 | 11:51 PM
b00gers's Avatar
b00gers
thanks.
im going the brembo blanks / AEM pads in front and undecided in rear route. i was also thinking about replacing the fluids with Valvoline SynPower
any links on HOW TO's?
Old Mar 12, 2004 | 02:16 AM
LT's Avatar
LT
Integra Brake Pads & Rotors
Integra Brake Caliper Removal/Replacement
Integra Brake Fluid Flushing/Replacing
Integra Brake Bleeding
Fairly simple stuff here.
Old Mar 12, 2004 | 03:27 AM
Asahi's Avatar
Asahi
Administrator
Blank Rotors
Cobalt GT Sport Pads (Street)
Ferodo DS3000 (Track)
ATE Super Blue
I would suggest looking into Hawk HP+ or Cobalt GT SPort if ytou want to improve your braking. The AEM are not that agreessive of a pad.
Old Mar 12, 2004 | 03:54 AM
LT's Avatar
LT
HP+ are meant for street and race. therefore, they will be a harsher material, thus more noise. And upon further research have the same coefficients of friction @ 200º and 600ºF as the ITR front pads (.45-.55).
I have a chart I made of some aftermarket pads and the EBC Greens have an operating temp of ~200-1200ºF, similar coeff. as the HP+; except have lower harshness on rotors, and a fairly low dusting. Greens' pad life is somewhere around 35K miles.
