Integra wont crank
Old Feb 13, 2006 | 06:12 PM
lugg_nuttz's Avatar
lugg_nuttz
Default Integra wont crank
Hey guys I have a 93 GSR I go out to start it it wont crank tried bypassing clutch switch even run a relay with push button, changed elec. part of switch ended up running wire from starter up to where I can touch to battery and it cranks. Any help Thanks Lugg
Old Feb 13, 2006 | 06:28 PM
Driverman5777's Avatar
Driverman5777
Is your battery dead or ur alternator bad?...
Old Feb 14, 2006 | 01:23 PM
lugg_nuttz's Avatar
lugg_nuttz
Default wont crank
No
Old Feb 14, 2006 | 01:25 PM
lugg_nuttz's Avatar
lugg_nuttz
Default wont crank
No they are fine I can run a jumper from stater wire to battery and it will crank and start , just not when you push in the clutch
Old Feb 14, 2006 | 07:03 PM
Driverman5777
huh thts weird is ur linkage bad?
Old Feb 15, 2006 | 04:35 AM
Phateless's Avatar
Phateless
S2K compatible
does it have an after-market alarm with some kind of stupid ignition kill? sounds like you're on the right track... good luck
Old Feb 16, 2006 | 05:24 PM
lugg_nuttz's Avatar
lugg_nuttz
No starter kill and also it starts with clutch 98% of time but the 2% kills me.
Thanks for input
Old Feb 16, 2006 | 05:50 PM
Driverman5777
does it start in neutral?
Old Feb 16, 2006 | 05:54 PM
lugg_nuttz's Avatar
lugg_nuttz
Default wont crank
When it does this it doesnt matter what gear no start
Old Feb 16, 2006 | 06:10 PM
Driverman5777
So even w/ the jumper cables, it woulden't start w/ the clutch in? I'm stumped
