90 integra still wont start?
Still having problem with the engine not starting. The Engine cranks and has fire on all 4 plugs. Fuel is getting to the injectors. How can I verify the all four injectors are not bad? What else could be the problem?
On 90-93, you might want to check the ignitor and distributor cap. Also might want to consider checking the main relay too. Check out the following link:
http://www.g2ic.com/forums/showthread.php?t=40859
Well since no one could answer the problem i stated i will follow up myself just in case anyone else runs into the same problem.
I swapped out the distributor with one from a 91 integra and it started. Both distributors have the same sensors in them and ohmed out the same . Both coils also the same and both have spark on the plugs. Yet for what ever reason the one distributor works and the other not.
Your coil might be weak.
