lsvtec head comparison Q's
Old Feb 6, 2006 | 06:53 PM
mountaindewguy's Avatar
mountaindewguy
Default lsvtec head comparison Q's
ok this isn't a typical 'why should i use this or that head' or 'which flows better'
but a couple questions to clear up the b16 vs. b18c questions when involving the LSVTEC
1. does it matter which b16 head? (i.e. 92-95 jdm b16a, b16a2/a3)?
cause i can get an OK deal on a b16a jdm engine...?
2. is there a difference in installing the 2? some people have told me the GSR over the b16 for ease of install, this true?
3. which b16 heads DO flow better? if any? i thought they were from the same casing...
4. which one has the highest compression if using b16a2 pistons?
what are the compresssion numbers with those pistons?
thank you.
Old Feb 6, 2006 | 06:57 PM
Driverman5777's Avatar
Driverman5777
You would want to keep your LS block. and the B16 head would more power at higher rpms. It has been done alot. I actually recomend the B16a over the B20z out of the CRV
Old Feb 6, 2006 | 07:56 PM
dubcac's Avatar
dubcac
I
Thats the whole point of an LSVTEC...he IS keeping the LS block. I don't know why you'd recommend the B16 over the B20. Every B20 swapped car I've seen has raped the B16 car. I hate to use the old cliche, but there's no replacement for displacement. Especially in an integra, the B16 just doesn't make enough torque.
thank you.
1. Yes it matters. Using a first gen B16 head means it's old, and has lots of miles. Valvesprings are worn, other parts of the head have lots more wear and tear. Casting wise, they are the same.
2. The only difference in the install of the different heads is the dual runner intake manifold of the gsr...requires a tad more wiring, and requires the use of a GSR ecu.
3. The GSR and B16 heads flow almost identically, but the GSR slightly outflows the B16 head at maximum valve lift. The ITR head is the same casting as the B16, but has a slight port and polish job...so it flows better than the GSR/B16 heads...but is a good amount more expensive.
4. The GSR head has smaller combustion chambers than the B16/ITR heads, and thus provides higher compression. Your CR would be around 11.59:1 with a GSR head, and B16 pistons in your LS block.
Old Feb 6, 2006 | 08:01 PM
Driverman5777
damn I need to do some studying I guess u've had a bit more experience than me thou.
Old Feb 6, 2006 | 08:53 PM
mountaindewguy
awesome, only question, if i plan on using an aftermarket intake manifold, would i have to worry about the problems with the GSR head/ecu/wiring? EVERYONE has recommended a 92-95 ex/si chipped (w/basemap) ECU...?
Old Feb 6, 2006 | 09:05 PM
dubcac's Avatar
dubcac
I
It's all good...I've been at this for way too damn long. :hs:
No, because the aftermarket manifolds get rid of the dual runners. If you run an aftermarket manifold, then you can run a chipped P28 ecu. If you use the OEM manifold, you must run the GSR P72.
Old Feb 7, 2006 | 01:06 PM
Driverman5777
So does that mean I could put an aftermarket intake manifold on my LS and have to use a GSR CAI?
Old Feb 7, 2006 | 03:42 PM
mountaindewguy
thank you!
Old Feb 7, 2006 | 03:45 PM
Driverman5777
If I used say a VEnom Intake Manifold on my LS engine would I be using the GSR CAI or the LS. and would a mod like that be worth it?
Old Feb 7, 2006 | 05:02 PM
dubcac's Avatar
dubcac
I
No, you'd still use the LS or Type R CAI. On the OEM GSR manifold, the throttle body sits lower than the LS/Type R. Using an aftermarket manifold puts it in the same position as the LS/Type R.
LS or ITR. The Venom IM is pretty pricey, and not worth the money IMO.
