- Integra motor swap questions?
- K20a Questions?
- Best Engine Swap for my CRX
- my b16 hatch wont start
- what engines fit a 92 civic
- Valve adjustment gone wrong for B18a ?
- which EMS?
- Chip
- enging swap
- What Trans????
- high or low impedence
- 93 civic losing power at 3k and up hills
- Engine build problem
- Thick black smoke???
- Flooding Problems w/ 1000cc's
- brake problems
- Smell of coolant - 98 Acura RL
- F22b tranny options?
- K20 to 92DA
- can i make my sohc b16 a dohc
- b16a2 Turbo or Supercharger?
- t belt question
- engine cutting out at cruise~help!!!
- 1997 USDM ITR Tech Help
- Xs Power cams
- b16a surging issue
- Maximum boost?
- ~Project D16Y6 to B18B~
- motor talk
- Broken H22 block, need some info
- question about my new motor?
- 97civic blew d16y8, is d16y8 from 00civic quick drop-in?
- what year is my trans??
- Conversion OBD0 to OBD1
- type R or a gsr engine ??
- i need help
- Lightened stock flywheel
- mini me swap??
- Turbo Manifold
- b18c5 type r engine into a 94 civic
- motor swap
- 90 accord died at light...
- automatic 92 civic dx/ 1996 B18B automatic
- b18c into a 92 civic
- Dizzy Rotor
- brakes
- Swap B18a1
- b16 on civic? need new tranny, too?
- question regarding GSR swap into civic sedan
- Help!! ACURA LEGEND problems
- cold air
- Torn between supercharging or all motor with my jdm itr...
- Cams B16A vs GSR B18 not Type R
- H22 , Type R Or B18b
- possible b16a SIR1 Obd0 swap questions
- Better
- b20 block wit everything else LS???
- How do you remove an altenator without removing the half shaft?
- Port and Polish, in San Diego CA
- oil pressure problem on a b16a
- B20 with VTEC head
- Which way to build for turbo
- Help: Is my altenator going bad?????
- Have a few questions on a GSR
- openions for what to stuff in my 89 crx
- Tuning in Hondata??
- B18C codes?
- Surprise cel code on the civic
- 99' civic Si b16 with turbonetics drag 3 kit?
- code 43 on ecu in a 90 LS
- He....lp! S4 flashiing atcu code 4
- Getting Hot Air
- cam seal or distributor seal
- k20a1 swap info plz
- Is the Craftsman 4-Ton, Low-Profile, High-Lift Floor Jack with Fast Lift worth buying
- b18a1 vs b18b1?
- Help: Is my starter going bad?????
- d16y8 into 95 EX
- b18a1 question
- 94 jdm gsr into 92 gsr engine light problems
- old buzz race car misfiring
- Engine For My Acura 95
- OK to run 10W-40 Mobil 1 in '96 Accord?
- missing plugins
- engin swap
- Swap ?
- Greddy Blue Box
- attention so cal swapers
- rod bearing question
- help w/88 teg to b16 engine swap
- 2007 civic SI injector ticking sound.
- H22A B.A.R Swap
- 91 b18 into 89 d16a1?? any suggestions?
- Need Help !!***!! w/ 1994 LS With Gsr Head and B20 Block
- Bracing misc. engine components
- H22 or B16?
- b18b head on a b20 block?
- Car is soo hot, and messed I'l never get to the dyno!!!! help please
- fans not working coolant evaporating
- is this right???????
- B18b
- Gsr swap loose ends
- H22A in ACURA INTEGRA 95
- H22a In Acura Integra 95
- CRVtec Help!
- Help With 94 Integra Ls Engine Swap
- Flywheel opinions for my set-up
- tearing down engine block
- B16 alternator, can i use different year!!!!!
- No CEL when key turned, won't start
- Safe Boosting?
- Hey Swap Gurus...I Need Some Help
- turbo exhaust
- Maintanence for 99 TL
- B16 swap into a 96 dx(need some info)
- 1988 Integra LS Special
- ls vtec oil pan leak
- Oil Squirters
- do i have to buy
- Ring Gap
- Motor swap
- tech help
- exhaust combinations?
- Tick Tick Tick.
- 94 teg gsr
- Piston to cylinder clearance
- after a new engine got dropped in
- 88 hatch with 97 b18?
- b18 rebuild
- ???msd???
- need advise on Tornado Fuel Saver
- HELP! electrical problem i guess
- help i am lost
- best place to buy b18c
- need advise on Fuel Saver Ionizer
- newbie w/ ?s regarding '91 accord w/h22
- Which type of injectors?????
- torque??
- b16
- Ls Vtec
- Td05H Turbo/Manifold Spacer?
- need pm7 pinout identification
- CAI: 99 DX; extra hose?
- AWD EP civic 2.4L 5 speed
- Wastegate dumptube question?
- lightened flywheel starter issue
- Integra turbo setup. Help
- integra b18 into a 93 civic hatch?
- JR Engine Management...Use it?
- Common Swap D16Y8 to B16
- B18A1 Wat to do help
- Losing Power in High RPMs
- bearings for ls/vtec??
- h22 5 spd into h23 auto prelude
- purge selenoid
- trouble code 10131
- Barometric Sensor - Code 13
- check engine light
- b18c1 swap
- Old 80 cvcc civic new B16vtec
- engine codes
- Aftermarket fuel pump...for the car or engine???
- CrVtecTurbo??
- B16A Question!
- no fire
- ls
- using abs axles on non-abs car??
- Swap info please
- acura cl 2001 1259 code
- 96 Rs To Gsr ???
- ITR All Motor..........What to do!?
- ls-vtec wiring
- Hone and piston size
- whats my redline
- What's ur fav exhaust for turbo setup?
- b18c5 swap question
- powersteering pump on b series
- replacing coil
- Huge Problem Need Help!!! Please !!! Anyone!?!?
- '95 civic trouble code 43
- So how hard is it to swap an H22 into a civic?
- Timing belt slipped; engine OK (sort of)
- Can someone shed some light.....
- b16w/ 171k miles...any suggestions
- swap OBD0->OBD1
- spray bar
- Fuel Pump
- 96 Accord lx replacement motor?
- what to do?
- What will happen if we used the wrong spark plug?
- Am I boost ready???????
- WHERE is ECU chip In Acura RL(3.5)?
- Brian Crower Internals
- spark plugs
- Help on swap from d15b2 to d16y8
- car problems
- 4340 lightweight crankshafts
- "The Beast"
- LS V-tec
- Swap 1986 D15A3 Si for B16B Type-R
- valve cover...things
- prelude injector
- tranny problem
- B18B Valves
- trouble code P1457
- anyone knows the KA24/20 injector rates, please?
- Catalytic converter?
- tires
- OBD 0 to OBD1 help
- H-beam rods in a b18b block
- F20B 97-98 Long Block
- GSR swap
- Safc
- When does vtec engage
- air intake
- Brake upgrade
- Clutch problems???
- b16 in a 1992 automatic integra
- '95 civic engine change now surging
- d16z6 f1 stage 1 clutch break-in
- Need Engine Help!!
- losing power between 3k and 4k rpm
- 90 accord engine rebuild
- anyone using crome 1.2
- swapping in a d16y6
- Installing a B16a2 in a 00 civic
- B16 problem
- 93 civic dx engine into a 91 Crx Si
- 96 Civic Question.
- B16a in a DC?
- 92 civic swap
- 92 civic swap
- Coils for a EK on a EG will it work??
- Rev-Limiter
- having problems with my acura
- Wierd idle problem tried fixing but stil there HELP!!!
- 97 accord radiator
- B18b B18C or B16A
- what is this part called and where can i get it cheap?
- 98 civic ex to si civic
- B18b with GSR head
- I need an explaination "please help"
- Bubbles inside raditor
- what should i do?
- wtb: turbo parts and type r rear sway bar
- b16a 350-400 whp
- help w/ my h22 accord
- b18c swap
- 2002 Civic EX
