help i am lost
Old May 7, 2007 | 09:49 PM
gsrsol's Avatar
gsrsol
slow and low
Default help i am lost
i just got done doing a swap on my 94 civic sedan. along with an auto to manual conversion while i was at it. i proceeded by trying to start the car i got nothing. the lights, radio, you know all the interior stuff was working, but i also heard this really fast clicking noise under the dash. so i look around to see what it was, still unsure of the noise i moved the ground on the head. i then try to start it again, this time the fuel pump came on, and the car cranked over but i don't think i had the fuel pressure in the lines or i then primed the fuel line, then the starter just clicked again, and i hear that clicking again. i determined it was the main relay. once again nothing no fuel pump again so i replaced the relay, and made sure all the grounds had good contacts now i am just getting the clickking and the speedo needle is bouncing around crazily. can someone please help me
Old May 8, 2007 | 01:23 PM
2001TEGGSR's Avatar
2001TEGGSR
Are you sure the battery is okay?
Old May 8, 2007 | 03:46 PM
gsrsol's Avatar
gsrsol
slow and low
not positive i am going to try to jump it later. it is reading 11.7 volts though.
Old May 8, 2007 | 03:56 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
11.7 volts sounds to me like a dead battery. It should be reading around 12.6 volts.
Old May 16, 2007 | 02:27 AM
mikeblancom's Avatar
mikeblancom
Default Clean the battery terminals
Sometimes this can happen when there is poor connection with the battery terminals. Take the cables off and clean the oxidized metal off the post and clamps.
