Motor swap
Old May 9, 2007 | 08:45 PM
aka-dk's Avatar
aka-dk
Caleb
Default Motor swap
Im going to put a '92 integra B18a motor into a 1993 integra. How hard is it to swap? Details please, as in what to take off to do it. Any advice would be appreciated, thanks.
Old May 9, 2007 | 08:57 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
The engine should just be a direct bolt-in replacement.
Moved to Engine Swaps.
Old May 10, 2007 | 04:43 AM
aka-dk's Avatar
aka-dk
Caleb
Will i have to take the tranny from the motor or will i be able to pull it out together?
Old May 10, 2007 | 05:44 AM
primetime's Avatar
primetime
Pull it out all together! How many miles on the motor though? if it is a high mileage motor that wasn't maintain very well then you may need to rebuild the bottom end with new rings, bearing, gasket seals, etc. etc.
Old May 10, 2007 | 06:59 AM
aka-dk's Avatar
aka-dk
Caleb
Well my brothers motor in his 93 integra is shot so im put my B18a in it, it has about 95,000mi. on it. It shouldn't be a problem putting it in with the tranny still attached would it?
Old May 10, 2007 | 09:30 AM
primetime's Avatar
primetime
No there should be any clearance issues. it better to drop in the motor and tranny together anyway!
Old May 10, 2007 | 12:12 PM
Provocateur
On permanent hiatus
Remove the old one as a complete unit with engine and tranny, remove tranny from motor, put on new motor, and drop in new motor/tranny. It should be that simple.
Old May 11, 2007 | 06:50 AM
aka-dk's Avatar
aka-dk
Caleb
I planned on using my tranny as well. That shouldn't be a problem right? It should mount up the same.
Old May 13, 2007 | 10:10 AM
aka-dk's Avatar
aka-dk
Caleb
Anyone???
Old May 14, 2007 | 04:53 AM
primetime's Avatar
primetime
Anyone???
everything will drop in!
