Best Engine Swap for my CRX
Old Jul 8, 2007 | 07:04 PM
IREAPERI's Avatar
IREAPERI
Default Best Engine Swap for my CRX
I'm getting a CRX and I want to put a better engine in it, I would also like to make it turbocharged, what engine would be the best to make my car fast?
Old Jul 24, 2007 | 05:45 PM
88_rex_si's Avatar
88_rex_si
if its a si you could keep the d16a6 and turbo it , that would be quick and affordable, or you could go the more expensive route and swap it a b16 , turbo that.. but expect to pay an arm and a leg ..good luck with the rex though
Old Aug 16, 2007 | 09:03 AM
93hondablk's Avatar
93hondablk
gtr
b16 turbo with low boost, or b18c1 turbo
b16 turbo will cost about 4k not including labor.
A gsr. add another thousand
Old Sep 1, 2007 | 03:00 PM
brandanintegra's Avatar
brandanintegra
go with a zc all you need is a head an intake and a turbo kit
pluss its a DHOC on your shoc block and trans ./go with si trans
Old Sep 28, 2007 | 02:01 PM
crx4lyf07's Avatar
crx4lyf07
if i were you i would go with the d16z6 vtech and turbo that it has vtch and you can use your axles and tranny so you would save money but i dont know correct me if im wrong good luck=)
Old Sep 28, 2007 | 02:07 PM
mr_malina's Avatar
mr_malina
Ford Guy
You probably are wrong because you can't even spell VTEC.
Old Oct 4, 2007 | 11:27 AM
Turbo_Chaos's Avatar
Turbo_Chaos
i would either go h22a if you have the money and time....if you want to go cheap look into either a LS motor or a DOHC ZC.....
Old Oct 6, 2007 | 06:26 AM
primetime's Avatar
primetime
LS or gsr, are your best choices! a turbo h22 is great, if you can afford to do it!
Old Oct 6, 2007 | 08:47 AM
Chiovnidca's Avatar
Chiovnidca
SOHC Powered
d16z6 + turbo = :chuckles:
Old Oct 21, 2007 | 08:43 PM
h2brex's Avatar
h2brex
the best would be k20 then h2b
