Installing a B16a2 in a 00 civic
Old Mar 21, 2007 | 11:58 AM
00civicB-series's Avatar
00civicB-series
Default Installing a B16a2 in a 00 civic
How do you install a b16a2 into a 00 civic ex.is there a way to bolt it up, or do you need to change all the wiring and ecu. axles? mounts?
Old Mar 21, 2007 | 01:31 PM
silvic00's Avatar
silvic00
if you have this many questions you should not be doing this yourself, did you try and search to see what answer you came up with, you will need another ecu and maybe conversion harness depending on obd series you got, axles, and mounts, and a tranny
Old Mar 21, 2007 | 09:27 PM
00civicB-series
i know, i looked everywhere for the answer but i couldnt get anything on a 99-00 ex,sohc vtec. the reseaon i would like to know is should i buy the whole swap or can i get away with what i need,it would save me some money. thank you for you reply
Old Mar 22, 2007 | 07:04 AM
99siDUDE's Avatar
99siDUDE
get a b16a2 from a 99-00 si with tranny. get the axles, ecu, shift linkage, radiator hoses, and the motor mounts. You can reuse your EX harness. It will work with the b16a2 sensors. You may have to run a few extra wires, but nothing major.
Old Mar 22, 2007 | 11:50 AM
00civicB-series
thanks alot, that really helps
Old Mar 26, 2007 | 10:36 PM
stereo's Avatar
stereo
if you get a complete 99-00 SI B16a2 swap it will bolt in harness and all just make sure you get the A/c and P/s bracket with the swap so your going to need them to bolt your stock compressor and P/s pump on.
