Thick black smoke???
Old Jul 4, 2007 | 02:23 PM
ccb18c's Avatar
ccb18c
Weetec
Default Thick black smoke???
Wats up all! I have a 90 ls with a b16a swap.My problem is when I hit vtec, I get a real thick black cloud of smoke. As my rpms go up in vtec the smoking decreases, but never clears. It also smokes heavely if I desell and then step on it. Im going through about a quart of oil a week. She dont smoke when warming up or before vtec hits. Any thoughts?
Old Jul 4, 2007 | 02:30 PM
foshomofo's Avatar
foshomofo
check the pcv valve...i had the same problem when i swpped my gsr in..could be it
Old Jul 4, 2007 | 04:09 PM
Snoopy's Avatar
Snoopy
been there done that
black smoke means you're running rich
Old Jul 4, 2007 | 05:49 PM
ccb18c's Avatar
ccb18c
Weetec
Stupid question, how do I lean it out?
Old Jul 4, 2007 | 05:52 PM
Snoopy's Avatar
Snoopy
first figure out why it's running rich. throwing any cel's? have you dont any maintenance?
Old Jul 4, 2007 | 06:33 PM
ccb18c's Avatar
ccb18c
Weetec
The motor was just rebuilt, so its straight. I am getting 2 cells, o2 sensor #2, and the knock sensor. I only have 1 o2 sensor, that I can find . The knock sensor is just bad I think. The cells dont always come, and the car still smokes when their not reading
Old Jul 5, 2007 | 03:12 PM
ccb18c's Avatar
ccb18c
Weetec
This is my manifold, almost dont think its for b16a jdm
As you can see I have only 1 sensor
Do you think this could be my problem?
Old Jul 6, 2007 | 11:09 AM
qtiger's Avatar
qtiger
The second sensor would come after the catalytic converter.
Did you buy this car modified from someone else?
Old Jul 6, 2007 | 05:36 PM
ccb18c's Avatar
ccb18c
Weetec
Yes, I bought it with the b16a and a turbo in it. The bottom end was junk from over boost, so I bought a 00 si b16a2 bottom and put that in with the jdm head. I also replaced the ecu with a new pr3 cause I wasnt sure what mods were done on the other ecu for the turbo. Cleaned the pvc and that helped but didnt cure.
Old Jul 6, 2007 | 05:37 PM
ccb18c's Avatar
ccb18c
Weetec
Also I dont have the other o2 behind the cat either
