Am I boost ready???????
Old Apr 8, 2007 | 04:30 PM
madman4you's Avatar
madman4you
Default Am I boost ready???????
Ok i have posted many questions before about things i needed to finish my project and what not..well after 4 long years of architecture school im going to be finished in 2 weeks..........so happy. Any how I havnt had much to research and what not and think about my car. I wanted to list everything i have for my project and wanted an answer as to having everything needed to boost this car.
I have a 91 crx si with a b16(obd0) first gen.
full turbo kit installed with t3/4 turbo,wastegate,BOV,FMI.
things i have not installed but have ready to install:
p72 ecu with hondata s200
turbosmart dual stage boost controller
RC 440 injectors,
ngk-BKR7E spark plugs
auto meter gauges
things i have to convert to obd1:
obd1 distributer
4-wire o2 sensor
obd0-obd1 wire harness
just wondering if im missing anything, was planning to go to the tune shop about a week after im out of school, so im just making sure im not missing anything large for this project...
was also wondeing if just taking the injectors clips from a 92-95 civic constitutes as obd1...
thanks for your help
Old Apr 8, 2007 | 04:38 PM
Snoopy's Avatar
Snoopy
been there done that
how much power do you want to make? those injectors might not be big enough.
Old Apr 9, 2007 | 09:27 AM
madman4you's Avatar
madman4you
sorry for got to add...only looking to get 240-260whp........
Old Apr 9, 2007 | 11:32 AM
18crx's Avatar
18crx
stock booster
they will work fine for that power. thats only about 10 pis if tuned properly so ur goals are real. thats good.
Old Apr 10, 2007 | 08:26 AM
madman4you's Avatar
madman4you
still need to know if i have everything i need?
Old Apr 10, 2007 | 10:59 AM
hondub's Avatar
hondub
^ -dub +da
Make sure you have enough charge piping to make it to the throttle body, you need some sort of downpipe to connect your turbo to the exhaust, make sure your injectors dont need a resistor box. If you run an obd1 ecu they might need one. Oh yeah and make sure you have oil feed and return lines and a tapped oil pan. Or you can tap yours.
Heres a couple links that will help you tremendously. Good luck
http://www.beesandgoats.com/boostfaq/g2icturbo.html
http://www.honda-tech.com/zerothread?id=1263795&
Old Apr 10, 2007 | 05:33 PM
madman4you's Avatar
madman4you
thanks for the info....but the whole turbo kit is properly installed with all the components..lol im more searching for info on tuning
Old Apr 13, 2007 | 06:43 AM
18crx's Avatar
18crx
stock booster
well yeah ull have to get it tuned. unless you can do it with the proper thnigs. i dont sugest it right off the top.
