Clutch problems???
Old Mar 27, 2007 | 06:21 PM
cerex's Avatar
cerex
Default Clutch problems???
i got a 98 civic ex and just put a stage 3 clutch and ultra light flywheel. sense i put it in every time i take off the car bounces real bad unless i rev up first and while the clutch is pushed in it makes a rubbing clatter noise can anyone tell me whats wrong? please
Old Mar 27, 2007 | 09:15 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Sounds normal to me. The clutch engagement is going to be harsh with a puck disk.
As long as it is engaging and shifting fine, it is functioning normally. It probably would have been wise to research before you put in a clutch not really meant for daily driving.
Old Mar 31, 2007 | 10:43 AM
mberndt's Avatar
mberndt
Agreed.
And the lightened flywheel will only help to make your drive even tougher.
Old Apr 4, 2007 | 05:18 PM
cerex's Avatar
cerex
well i am still really sure that there is something wrong because i decided to bleed the clutch and once i did it drove fine and shifted normal with out the noise but after 2 days the noise came back is it possible that the throw out bearing or the fork is not on correctly?
Old Apr 4, 2007 | 05:20 PM
cerex's Avatar
cerex
it seems that the throw out bearing is not engaging or letting out correctly could that make the noise
Old Apr 5, 2007 | 02:54 PM
2001TEGGSR's Avatar
2001TEGGSR
If it worked fine after you bled the system, the Slave cylinder or the Clutch Master cylinder might be leaking.
Old Apr 7, 2007 | 05:30 PM
cerex's Avatar
cerex
how do i check them?
Old Apr 7, 2007 | 05:33 PM
2001TEGGSR's Avatar
2001TEGGSR
Do you see any leaks? Are you loosing fluid?
Old Apr 8, 2007 | 05:18 PM
cerex's Avatar
cerex
no everything is clean and no fluid loss... its the wierdest thing has to be something with the throw out berring because it only does it when you push in the clutch its like its not going in or out all the way?
Old Apr 8, 2007 | 05:58 PM
2001TEGGSR's Avatar
2001TEGGSR
Try adjusting your clutch pedal, http://www.team-integra.net/forum/di...g+Common+Topic
