HELP! electrical problem i guess
Old May 7, 2007 | 10:01 PM
gsrsol's Avatar
gsrsol
slow and low
Default HELP! electrical problem i guess
i just got done doing a swap on my 94 civic sedan. along with an auto to manual conversion while i was at it. i proceeded by trying to start the car i got nothing. the lights, radio, you know all the interior stuff was working, but i also heard this really fast clicking noise under the dash. so i look around to see what it was, still unsure of the noise i moved the ground on the head. i then try to start it again, this time the fuel pump came on, and the car cranked over but i don't think i had the fuel pressure in the lines or i then primed the fuel line, then the starter just clicked again, and i hear that clicking again. i determined it was the main relay. once again nothing no fuel pump again so i replaced the relay, and made sure all the grounds had good contacts now i am just getting the clickking and the speedo needle is bouncing around crazily. can someone please help me
Old May 24, 2007 | 11:16 PM
theturbocrx's Avatar
theturbocrx
When you did the auto to manual conversion did you change the ecu to one thats for a manual trans?
Old Jun 24, 2007 | 10:06 AM
flappy188's Avatar
flappy188
O.G. SON!
try charging your battery, sounds like it might be a little low.. if not that sounds like a starter problem... i say the battery tho.
