Dizzy Rotor
Old Jun 16, 2007 | 07:48 PM
A-series's Avatar
A-series
v-card member alpha
Default Dizzy Rotor
I was curious if you guys would use this rotor that I purchased.
It looks different from the old one I'm replacing which to my knowledge is oem or oem style. :hsdunno:
The one that was in there had sort of a fiber material on the sides of the top part ( ) whereas this one not only has no fiber but exposed metal on the sides (highlighted area in pic) and it's a different material as the oem style is silver.
Also, this new one I got has teeth, or grooves in the top part instead of the smooth finish on the oem one.
It's a GP Sorensen, the only one they had in stock for my car at the place I went.
I didn't realize it looked noticeably different until I got it home so I'm curious what your opinions are.
The 1st pic is of the one I just got.
The 2nd is the highlighted area of concern that is both diff. color, no "sides" and has teeth (hard to see)
The 3rd is a pic I found online that looks very similar to the one that is currently on the distributor.
This may not be the best place to post this but what ya gonna do.
Thanks in advance for any input/opinions.
Almost forgot, it's a '92 Civic EX that I'm putting it on, if it makes a difference.
Old Jun 16, 2007 | 08:49 PM
FooD2000's Avatar
FooD2000
Still Water
i've always used the aftermarket typical parts store dizzy cap/rotor for my cars. It's just plastic and a contact right?
*shurg*
Old Jun 16, 2007 | 11:21 PM
A-series's Avatar
A-series
v-card member alpha
*shurg*
ty for response
Well, I'm sure it will both fit and work.
I'm just not sure if that style rotor, the one I just bought (I've never seen one like that before), will provide the same performance/fuel economy as the more "traditional" style that I've seen in the past, including what's currently on my car.
It was only about $13 so normally I'd think no harm, no foul but for some reason I have doubts as to how long it will last compared with an oem rotor and what possible affect it might have on anything else under the cap.(I'm assuming there are "fiber" "sides" on other rotors for a reason )
Anyway, I'm pry just being paranoid but I don't want to remove the machine screw (from what I understand it's relatively soft metal) for the rotor yet again if there's a chance I'll need/want to replace the rotor soon after since that machine screw is old, has been removed and re-tightened who knows have many times and I've been unable to find a suitable replacement.
At least the current rotor will suffice until I make up my mind
