mini me swap??
Old Jun 20, 2007 | 08:44 PM
Single Cam's Avatar
Single Cam
SOHC 4 door
Default mini me swap??
what is a mini me swap? and will a 1.6 SOHC vtec head fit on my d15b2 block and is there any advantage to doing this?
Old Jun 22, 2007 | 11:22 PM
Single Cam's Avatar
Single Cam
SOHC 4 door
is there anyone with any kinda intellegence on this site that actually knows how to reply to someones posts? because if so, i havent found them yet.
Old Jun 24, 2007 | 10:12 AM
flappy188's Avatar
flappy188
O.G. SON!
a mini me swap is when you put a v-tec head on a non v-tec bottom end.
basically you are adding v-tec to ur non v-tec motor.
if the motor you are talking about having is a civic CX motor, then No, you cannot add a v-tec head to it.
there is other things that would need to be changed as well, like ecu, wiring, gaskets and all that. so it is a time consuming project.
any other questions? BTW I see yer from the burgh....Me too.. I'm south of it tho...
Old Jun 25, 2007 | 10:10 PM
Single Cam's Avatar
Single Cam
SOHC 4 door
im south of pittsburgh too. Its a dx motor with a vtec head on it...
