question regarding GSR swap into civic sedan
i've searched around but can't not find the answer i'm looking for. i have a 97 GSR swapped onto a 95 civic 4dr..the guy that did the swap for me tried to hook up a/c and power steering but could only able to hook up the power steering utilizing the civic ps pump, but not the a/c..Said there isn't room..what i want to know is, is there anyway i can get both of this hook up?? i can get the oem ac comp and bracket and ps pump and bracket for a good price..
what i need to know is what can i do in order to make this work so i can have both power steering and a/c..
please help
thanks in advance.
please help
thanks in advance.
If you use the 94-95 Del Sol VTEC bracket, you should be able to hook up the air conditioning. I haven't personally done the swap, but I don't think that room would be much of an issue.
Can you take some pictures to see how much room you are actually working with?
here's some pics of the engine bay..on one of the pic of the belt for the power steering u can't see that it doesn't line up correctly but it does..that's y i bought the oem gsr power steering with bracket and a/c comp with bracket..it's on it's way soon..u can see that i aslo bought slim fans to give it some more room to work with..i hope this way i can have a/c soon..
thanks for ur help so far.. :-)
if u need one for a different angle let me know..i'll try to get one..
sweet..so u think the del sol a/c bracket would fit nicely?? i already paid for the gsr oem bracket and such..i'm gonna try that and see, if it doesn't work then i'll look for the del sol vtec bracket..
thanks
thanks
