question regarding GSR swap into civic sedan
well i got it to fit perfect with the bracket i bought from a guy on ebay..the only problem i'm dealing with now is the ac hose..i got one hose to fit perfectly but the other "gsr" hose would not fit..here's a picture of what i'm talking about:
is there any other a/c hose i can use to make this fit nicely without having to chop up the current one i have?? the long hose i got have too many bend to it..plus it doesn't have this pressure valve on it like the other civic i have at home..one have a blue cap with a letter "L" and the other have "H" on it.
i don't know if the second hose require to have that presure valve or watever u call it or not..
Hope Mods don't mind i put this here.
i know some of you will say this fall under the Engine Swap forum but, it's been there awhile and no-one answer my question..hope i can get more input from here..
97 gsr into 95 civic sedan..
a/c compressor mounted up great..gsr a/c hose that goes to condensor only fit one..the other doesn't fit..
what hose can i buy to make this work?? i need both pressure valve to work in order to get a flush and refill.
here's pic:
Pics removed to conserve space -- see original post at top of thread -- TheOtherDave™
thanks
here's pic:
thanks
Last edited by TheOtherDave™; Jul 8, 2007 at 06:51 PM. Reason: Pics removed to conserve space -- see original post at top of thread.
What the hell happened to your high pressure hardlines?
And yes, you need them to have functioning A/C.
My recommendation would be to take this mess to an A/C specialist who can fabricate a hose with the correct fitting on the compressor end. And considering how mangled the hardlines are, I wouldn't be surprised if they begin to leak.
EDIT: Having merged the threads and seen all the original pics... my suggestion is to re-plumb the entire high-pressure loop by using new Civic hard lines and a custom hose to connect to the A/C compressor.
Merged and moved (again) to Engine Swaps.
Please...DO NOT create duplicate threads in multiple forums; it's an absolute nightmare for us to clean up. :a:
^^^that line is from the GSR line dude..it come with the gsr compressor, which come with the engine when i bought it..
my car is a 95 civic..that's y it wouldn't fit.. nor does it have that pressure valve on it..
The point that I (and Provocateur) have been trying to make is that the high pressure fitting should be at the end of the hardline, near the centerline of the radiator support.
Since I can't find the end of the hardline in your photos, I can't help you re-orient those lines to get the fitting back where it should be.
Which is why I suggested that you re-plumb the entire high pressure side of the A/C system.
