Engine For My Acura 95
Old May 28, 2007 | 10:47 AM
Firewalker's Avatar
Firewalker
Default Engine For My Acura 95
I HAVE AN ACURA INTEGRA 95 AND IM GONNA SWAP FOR A B20B
ID like to know what i can change on the engine gto boost it ( +20 hp at least )
and if it's worth for the power involved... what kind of turbo should i install on it
thanks alot for your help
Old May 28, 2007 | 05:12 PM
KaoticBRD's Avatar
KaoticBRD
Why not boost the Motor thats in it?
Old May 28, 2007 | 07:33 PM
2001TEGGSR's Avatar
2001TEGGSR
If your going with a B20, I wouldn't do anything without sleeving. While it is possible to squeeze 280 whp, B20 OEM sleeves are notorious for cracking.
If your trying to keep things on the low cost side, your better off boosting a stock B18.
Old May 28, 2007 | 09:17 PM
Firewalker's Avatar
Firewalker
my b18b head is finished... im gonna change the engine at all seriously.. should i get a b18b or a b20 b....
b18c is like twice the price or even more for 30 more hp... is it worth for real
i have an automatic transmission by the way..
Old May 28, 2007 | 09:32 PM
2001TEGGSR's Avatar
2001TEGGSR
Your automatic is not going to do you any favors, they don't respond to power very well. While you have the motor out, a 5 speed swap will be the most cost effective solution to increase the longevity of your drivetrain. Keep the automatic, and be prepared to replace it very soon.
Are you buying a short block, or building one yourself?
Either way, unless you plan on sleeving I would stick with a B18b. Nows the best time to reinforce your rotating assembly as well. If its in your budget, grab a set of forged pistons & rods and you can easily achieve 350 whp. If not, at least look into having the OEM b18b rods machined to use ARP rod bolts.
