i need help
Old Jun 20, 2007 | 09:40 PM
a92acuraintegra's Avatar
a92acuraintegra
Default i need help
me and a buddy are putting a b18a1 motor and tranny into a 91 civic hatch and are having trouble with the front suspension the wheels lean out what suspension and axles should we be usingmad:
Old Jun 21, 2007 | 05:12 AM
primetime's Avatar
primetime
what axles are you using now???
Old Jun 21, 2007 | 09:09 AM
a92acuraintegra
Default a92acuraintegra
we are using the axles out of the 91 integra non abs
Old Jun 21, 2007 | 09:11 AM
a92acuraintegra
Default me again
we are also using integra suspension all way round
Old Jun 21, 2007 | 09:24 AM
primetime's Avatar
primetime
most swap usually call for just the axles, not the whole suspension set! you're going to need an adustable camber kit.
Was the integra suspension stock or aftermarket?
Old Jun 21, 2007 | 03:50 PM
a92acuraintegra
Default hey
the integra suspension is stock and i thought the civic spline was different from the integra that integra axles wont fit the civic suspension and if we use the integras will a camber kit work
Old Jun 21, 2007 | 09:14 PM
18crx's Avatar
18crx
stock booster
no the splines are the same as an si or dx civic /crx just change the upper control arms and then the camber will be fine. the upper arms on the teg are longer.
