PDA
View Full Version : Integra & '97-'01 Integra Type-R
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 [31] 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87
  1. 89 integra swap?
  2. Try To Ban Me Now Bish!
  3. Tokico Blues and Skunk2 coil overs dont quite fit
  4. All Motor
  5. Weird buzzing...
  6. SOS need window help
  7. Rough Ride
  8. A few questions...
  9. Hi All!
  10. new member
  11. STOLEN 3/31/05 Olympia, WA 00-1390 FBP
  12. Idle tensioner/timing?
  13. Rev Limiter TOO LOW
  14. Front lip anybody?
  15. 94 Integra wont start
  16. zc motors
  17. 1993 Teg RS 5 speed - White
  18. Front End Delayed Again!
  19. Resetting the ECU question
  20. do i need crank balancing???
  21. Stripping out a 92 Integra GSR
  22. There should be more distributors for hondas...
  23. Got some 450cc injectors
  24. what year integras are obd0?
  25. type shocks question
  26. Help For My 1994 Acura Integra
  27. question about a/c and radiator fans
  28. Broken Brake Line
  29. Head mods...what about block
  30. Smoking intake manifold and leaking injectors
  31. modding the stock intake
  32. Side Mirrors
  33. Car won't start.
  34. Teg Question?
  35. fuel efficiency - integra LS
  36. Looking for Hi-Flo Cat on Integra Type R
  37. 93 Integra RS
  38. camber kit
  39. PR4 vs. P75
  40. Is there an online manual 4 tegs?
  41. S2000 Antenna Conversion??
  42. No Heat in 91 GS
  43. does going turbo means no a/c ?
  44. Aerodynamic drag...our biggest enemy!
  45. jdm intake manifold
  46. Couple O' Questions
  47. Rattling in 2nd and 4th
  48. 98 Integra LS Exhaust
  49. Seat belts?
  50. started turbo up, bad sputtering
  51. 90 Teg/B16A.Can it convert to Hydro Tranny
  52. 93 teggy
  53. G2 shocks/springs Combo on G3 ?
  54. Abs problem
  55. Brake Question
  56. Vtec system
  57. troubleshooting fuel problem.
  58. squeek in my front left
  59. Coilovers
  60. Bout done...
  61. straight pipe?
  62. Precautions for stored ITR
  63. which press to use?
  64. okay guys im gettin 500 bucks
  65. Air Conditioning Compressor Clutch Relay
  66. how much does turboooooo
  67. stuck deciding between wheels...
  68. Need Gauges
  69. water leaking from my power auto seatbelt..help
  70. Turbo is 75% in!!!!!!!!! =)
  71. Looking for used exhaust for teg
  72. greddy gsr blue box turbo plug in
  73. Easiest way to replace rear firewall mount?
  74. mods suggestions
  75. Mechanical Expertise in NY Area?
  76. How hard is it to drop the oil pan and put a new gasket?
  77. gsr exhaust
  78. installed fluidyne radiator on 2000 gsr with slim ac fans
  79. code 14 came on, electronic air control.help!
  80. Brake Pedal
  81. Depressing the rear brake caliper piston.
  82. oil catch can help
  83. More on intakes please!!!
  84. shift linkages?
  85. turbonator?
  86. valve cover swap
  87. Acura Integra LS, improve HP
  88. Quarter Panel?
  89. LS 97 integra info?
  90. Tail Light for 2001 Integra
  91. turbo
  92. Any ITR owners in the NYC area want to have a meet before EXPO 5 ?
  93. Skunk 2 Pro series Manifold
  94. hole in radiator buying koyo alum racing rad for 00 gsr
  95. Oem Side Skirt Replica
  96. b18a head
  97. new setup
  98. Bent jacking point???
  99. installing JDM OEM side marker ??
  100. Motor mount inserts?
  101. Just posted my car pictures
  102. fog lights install
  103. Lookin for CHEAP Exauhst(dont grade on spelling)
  104. Need part number (pic inside)
  105. What is a 96 Type R worth?
  106. Replacing stock (gsr) spoiler with type R spoiler....
  107. New springs, what compression level?
  108. how much would it cost to paint front and back bumper?
  109. change timing belt with new engine?
  110. Headlights wire connect to where?
  111. Hood Problems
  112. need some timing help
  113. ::EEEK:: cali smog!!
  114. help please IAT sensor?
  115. where is located mi AIT senson on mi integra 98
  116. Yellowing Headlight Plastic
  117. Running Rich
  118. can you put
  119. Gas Indicator is lying
  120. oil pan messed up thread
  121. Valve Adjustment Tool
  122. LS Tranny Problems: Please help
  123. burning major oil hurt performance?
  124. Can i run both headlights with one power sources
  125. hard to get 95 turbo teggy smogged? nor cal
  126. Black Emblem
  127. what does this little black button do ?
  128. Need a good autoshop that does electrical around So.Cal area
  129. ZC engine swap
  130. repainting wiper arms...
  131. 13s GSR
  132. LS Performance Cams- on an auto trans?
  133. looking forcomplete B18c1 94-95 vtec head
  134. drive or not???
  135. Maintenance Recs
  136. Where to get rear discs?
  137. ???93 teg/b18c5 wiring vtec??
  138. short shifter cons ?
  139. Headlights keeps going out?
  140. Headlights keeps going out?
  141. Help: What's wrong with my ABS?
  142. 95 GSR I hear you knockin'
  143. paint job...
  144. Integra B18 Head Studs?
  145. Window Tint
  146. Peeling Paint
  147. 96 GSR vs. 04 SVT Focus
  148. New car for mom
  149. 95 GSR service light
  150. AC Wowws, New Evaporator core due
  151. Where to get Couplings? Injector question
  152. leaking water
  153. Modify The OEM GSR Intake Manifold?
  154. BREAK indicator in the dashboard is always ON
  155. Wiper blades
  156. Your Opinion Fast?
  157. Will an RSX shift knob fit an Integra?
  158. welp, my motor is burning oil :sigh:
  159. manifold heat sync?
  160. Can anyone get me a carfax report?
  161. Desperately Looking
  162. FINALLY...i got my R!!!!
  163. o2 sensor wire diagram????
  164. fronts doors speaker brackets
  165. ??93 tig b18c5 swap??
  166. Performance Module
  167. state ref ticket last night
  168. Drag coefficient for integras?
  169. JDM Teg Conversion
  170. DC2 Integra Type-R air flow!
  171. Blower motor and radio problems in '91 Teg
  172. help me out with CEL, dont know if this is normal or not
  173. Vafc Question?
  174. Help with CV Axle
  175. Side Skirts & Rear lip
  176. b18a1
  177. AC problem???
  178. Jdm integra bumper w/ antenna or bumper pole
  179. Question regarding fouled plugs
  180. pcv system help (little black box removal)
  181. Alternate Tire Sizes for '96 Special Edition
  182. 2001 drivers side floor mat
  183. thermostat housing
  184. Pistons???
  185. tranny help!!!!please help with ??
  186. 95 obd1 GSR saturated type injectors?
  187. Ls Block.. With Weisco Piston...
  188. Just Thought I'd share what came in the mail today...
  189. <---Please help ASAP, Car totalled---->
  190. Turbo ruining my paint
  191. Valve Spring Compressor
  192. exhaust?
  193. Cam suggestions? please?
  194. clicking and scraping noises
  195. Concerning ls/vtec head gasket?????
  196. will 95 seatbelts go in a 98-up integra?
  197. 98-01 rear bumper lip JDM
  198. Check out my Integra
  199. Supe up an 89 Integra?
  200. obd-0 and obd-1 advantages and disadvantages?????
  201. mysterious C3
  202. Burning Oil
  203. VTEC in my GSR
  204. GSR gauges
  205. Engine Designations location?
  206. Help on headlights...
  207. 1992 Integra Rims
  208. Throttle body for GSR
  209. Help needed installing angel eyes
  210. Help, crank but no start.
  211. Any PICS of an SRI installed in your GSR? Need some help!
  212. Greddy Turbo Re-Tuned
  213. Clutch question?
  214. Jdm Gsr Ecu?
  215. How do I fit EBC Redstuff brake pads to DC2 Type R?
  216. How do I fit EBC Redstuff brake pads to DC2 Type R?
  217. Us Integra Engine Vs Jdm 90-93
  218. another ITR cam question
  219. Smoking help
  220. 90 integra timing belt
  221. Anyone here with a 93 Integra LS what RPM at Top Gear??
  222. How much Whp you think?
  223. S80 Transmission in my GSR?
  224. Im new here
  225. Semi Loud BOV + Intercooler questions
  226. can someone id these wheels
  227. anyone have the Spoon Sports shift knob???
  228. how can you tell ?????
  229. pads!!!!!1
  230. LS TURBO vs. GSR TURBO
  231. Cold Air AEM Induction Kit for Honda ITR DC2 1999
  232. Taking the door apart on a UK Honda 1999 DC2 Type R
  233. o2 sensor and belts...
  234. Speaker size: 1992 integra
  235. GSR with P28?!
  236. Power gains from new Cams....?
  237. O2 sensors
  238. grabby and slippy clutch.....
  239. anybdy have problems removing the crank pully bolt?
  240. type R cams
  241. P0740 transmission code - weird problem
  242. itr strut bolt up
  243. whats the difference between 90-93 integra
  244. See ya - no more Integra
  245. Resetting maintenance light- 94 integra LS?????
  246. My 1990 Integra wont start
  247. special kit or bracket for type r rear sway bar on LS
  248. Trailer Hitches...
  249. auto seat belts on 91 teg?
  250. Difference between 89 and 90 integra?
