Rev Limiter TOO LOW
Old Mar 31, 2005 | 05:20 PM
B18C3GSR's Avatar
B18C3GSR
Default Rev Limiter TOO LOW
I just got gauges in my GSR and have noticed that the check engine light is on and the rev limiter is stopping me at 6500. What gives???
Old Mar 31, 2005 | 06:42 PM
dubcac's Avatar
dubcac
I
The limiter is lower because the CEL is on. For certain codes the CEL throws, the ECU puts the car into limp mode, scaling back on timing and lowering rev limiter, so you don't cause damage. Check the code.
Old Apr 1, 2005 | 03:44 AM
SP00NFed's Avatar
SP00NFed
FuK JDM
try resetting the ecu?
Old Apr 1, 2005 | 04:26 AM
reno96teg's Avatar
no.. check the code first. why people opt to ignore the CEL is beyond me..
Old Apr 1, 2005 | 05:16 AM
Illegal B16's Avatar
Illegal B16
New Zealand
Old Apr 1, 2005 | 01:19 PM
honda94vtec's Avatar
honda94vtec
Honda94VTEC
yea everyone thinks the ecu is R2-D2 it will fix your problem and be on your way..... check the codes dude!
Old Apr 1, 2005 | 01:32 PM
PikkaGTR's Avatar
PikkaGTR
Power of Dreams
yep check wut is wrong then FIX it
once the code goes away, you will be able to rev once again
Old Apr 2, 2005 | 12:20 AM
mikey16556's Avatar
mikey16556
exactly, the code came on for a reason. if you reset it and rev it up back over 8 grand and cause damage im sure it will be worth that one last rip right
Old Apr 2, 2005 | 04:55 PM
B18C3GSR's Avatar
B18C3GSR
well i cant get to the dealer to get the codes checked... could it be an O2sensor or something?
Old Apr 2, 2005 | 05:28 PM
you can check the code yourself, find your ECU under the dash, see the flashes, actually you know what start with this
http://www.c-speedracing.com/faq/03.php
its the best i found in a short amount of time so just read, click through the links, and follow
