do i need crank balancing???
Old Mar 31, 2005 | 07:58 AM
ginomobile/teg's Avatar
ginomobile/teg
Default do i need crank balancing???
Hey everybody I have a 90 integra gs completely stock, i want to put some p30 pistons into the bottem end so i can get more compression, only thing i was wondering is.......do i need to get my crank balanced when i have the p30 pistons instead of the stock pistons.
Any help would be great thanks guys
Old Mar 31, 2005 | 09:03 AM
Running925's Avatar
Running925
Your Powder Coater
have it lightened & then have the whole bottom end balanced & blue printed
Old Mar 31, 2005 | 03:48 PM
dubcac's Avatar
dubcac
I
To answer your question, no, it is not necessary. If you were doing a motor build up to handle higher RPM, then I would suggest it.
Old Mar 31, 2005 | 04:04 PM
honura's Avatar
honura
Seni
Yeah do it anyways! You might as well the block will be apart so hey why not peace of mind.
Old Apr 1, 2005 | 03:56 AM
ginomobile/teg
what do i have to send in when i get it balanced? the complete bottem end? how does that work?
Old Apr 1, 2005 | 07:17 AM
ISP James's Avatar
ISP James
DAMIMRED
you can just send the crank in and have it turned and balanced.
if it were me, id have the block honed but not bored (bore it and those PR3's wont fit right), have the crank turned and have the top of the block checked for plane. chances are, it is okay but better safe than sorry.
and if you dont have PR3 pistons yet, let me know i have a 3 set i will sell you cheap.
Old Apr 1, 2005 | 07:37 PM
ginomobile/teg
okay so what about the p30 pistons, the will fit okay wont they? And why is it better to have the block honed instaed of getting it bored? Anybody know how muc p30 pistons cost?
thanks
Old Apr 2, 2005 | 05:24 AM
ISP James's Avatar
ISP James
DAMIMRED
if you have it bored, that increases the diameter (bore) of the cylinders and thus, you will need to get pistons that are built for such.
a hone simply smooths the cylinder walls down so that your rings seal better but does not (significantly) affect the bore dimension.
Old Apr 2, 2005 | 02:29 PM
ginomobile/teg
This may be a little off topic but, when i put these new p30 pistons in I am expecting to have 11.4/ 1 compression or so, but is this compression too high to be using pump gas, I still have to drive this car everyday and i want to use pump gas. Tell me if you think i should use some lower compression pistons or not.
Old Apr 2, 2005 | 05:20 PM
ISP James's Avatar
ISP James
DAMIMRED
you will be okay with pump gas if you run premium fuel, probably wise to run 92/93 if its available in your area but 91 might suffice as well.
