Turbo ruining my paint
Old Mar 16, 2005 | 07:56 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Default Turbo ruining my paint
I know it sounds weird but the paint on the hood right above the turbo manifold is starting to turn a brownish color from the heat generated by the manifold. I was wondering what would be the best solution to prevent the damage from getting worse.
Could I put some heat wrap on the underside of the hood to prevent the heat transfer? Or could I wrap the manifold in heatwrap? What is the best solution.
Old Mar 16, 2005 | 08:09 PM
HoNdAeVo's Avatar
HoNdAeVo
I railed YOUR sister.
you could put a head shield over the manifold...
Old Mar 16, 2005 | 08:18 PM
craig5_12's Avatar
craig5_12
I would want the manifold to be able to 'breath' as much as possible so I wouldn't wrap it as that wouldn't allow heat to escape. I would look at getting some type of thin insulation and putting that on the hood, hey even tin foil might work....if not though Home Depot has some stuff you could use.
Provocateur
On permanent hiatus
I had the heatshield on but I took it off and when I went to put it back on, one of the bolts broke off inside the manifold, so now it would rattle without the other bolt.
Old Mar 16, 2005 | 08:39 PM
craig5_12's Avatar
craig5_12
Did the head bust off the bolt when you were tightening it? If so then a piece of the bolt should be sticking out. Put some heavy duty pressure on some vice grips and pull the rest of the bolt out. If you already went that route and the bolt broke again, you may be able to drill it out and put a "heli-coil" in there, but not sure if you could. Those exhaust bolts are a major PITA! A bit of advice is to buy some bolt extractors! Mine are made by IRWIN (maker of vice grip) and I swear by them now, wouldn't try and remove a tough bolt without them!
Old Mar 16, 2005 | 08:53 PM
dubcac's Avatar
dubcac
I
You can wrap the manifold in heat wrap, and also put some on the underside of the hood...should help a lot.
Old Mar 16, 2005 | 08:59 PM
Provocateur
On permanent hiatus
I was thinking that, but I would probably have to remove the whole turbo to wrap it up, so maybe just some heat wrap under the hood. Now, how would I secure that, or do they make sticky heatwrap?
Old Mar 16, 2005 | 09:07 PM
dubcac's Avatar
dubcac
I
You could do an insulation with reflective surface on the underside of the hood as someone else mentioned. If you used heat wrap, you could use some double sided tape maybe?
Old Mar 16, 2005 | 09:46 PM
jr_kbad's Avatar
jr_kbad
go to a junk yard and rip them of a DSM turbo from under the hood.
Old Mar 16, 2005 | 10:36 PM
95tegRS's Avatar
95tegRS
you could always get rid of the turbo. I dont mind taking it off your hands (give you some more space in the garage)
