How hard is it to drop the oil pan and put a new gasket?
www.ufc.com
Well I just got back from Goodyear to have my oil changed. (i don't like the mess) and it was brought to my attention that I have seapage. Not yet a class one leak, but the price would be 230 to repair. I thought that was a little high to change out a gasket. So I thought I would check with you guys and see if I should do that or just buy the hasket from Acura and do it my self. Thanks in advance...
On permanent hiatus
That is about the amount I was quoted for the job. I did it myself in an hour and a half and paid $20 for the new gasket. You may also need to remove the front and rear engine stiffeners and flywheel cover to get at the last 3 bolts holding the oilpan on. The worst part is trying to get the gasket to stay in one place when you are putting the pan back on.
www.ufc.com
Originally Posted by Master Yodub
I'd rather use hondabond than superglue, or some sort of silicone gasket maker/sealant.
The deer had to die!
