Help needed installing angel eyes
I recently bought a new pair of halo projector headlights and dont know how to install them so that the halos are lit up. right now they light up like ordinary headlights. there are red and white wires that i think control the halos but i dont know where they go. its soo aggravating!
did you get any type of installation manual for these lights? one of those wires is most likely looking for 12v(should be the red one) and the other is ground. you can get the 12v from your parking lights and put the ground to the cars chassis. don't forget to put a inline fuse on the wire that goes to 12v!
well, my guess as that one red and one white goto each light. and your right, they need to goto one of the side marker lights. now your only problem is verifying which one of those wires is used for 12v. check your instructions and see what they say. then use a multimeter to test to see which wire off of the side markers is getting 12v when the parking lights are on(use the bulb thats on when the parking light are on). then connect that wire and put the other to ground and you should be in business.
the red wire goes to the red wire on your parking lights and the white ones goes to black wire on your parking lights, (it will be easier if you twisted both white wires coming from the halo light together and then run them to the black wires on the parking light, same for red wires on halo.
see if that works
see if that works
i just install a a pair of halo on my 94 integra myself last week. i think i did it wrong but im kwel with it. i connected it to the side marker. i hook the halo wire up the 194 blub on the side marker(the one with smaller blub or only two wire, not 3, one is green and other is black) the green wire is the postive or 12V and the black is the ground. most likely, connect the red halo wire to the green wire and white to the black. the only problem with is setup is that blink or use ur turn signal when u turn, the halo on the headlight will blink along with the corner light. i think it pretty badass but didnt notice it until i completed the installation. i didnt fix it becuzz too much of a hassle to take off the bumper again, so i left it the way it is.
