Aerodynamic drag...our biggest enemy!
Old Mar 29, 2005 | 04:55 AM
LT's Avatar
LT
The deer had to die!
Default Aerodynamic drag...our biggest enemy!
actual technical stuff! in the Integra forum!
Originally Posted by MichaelDelaney of Team-Integra.net
HP loss due to Aerodynamic Drag= [Cd * A * (V^3) ] / 150,000
where:
Cd = drag Coefficient
A = frontal area in sq. ft.
V = Velocity (speed) in MPH
Cd for all gen Integras = 0.32
Frontal Areas (ft^2 )
Gen 1 20.16
Gen 2 nonVTEC 24.47
Gen 2 VTEC 19.54
Gen 3 20.50
20 MPH = .35 Hp
60 MPH = 9.4 Hp
90 MPH = 31.9 Hp
Old Mar 29, 2005 | 06:07 AM
carta79's Avatar
carta79
Life after death
So the best way to counter this drag would be to slap on a big ricey body kit right. :chuckles:
Old Mar 29, 2005 | 08:05 AM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
Great find! [I'll copy this over to the Integra FAQ.]
And .32 is fairly low for production cars.. so consider the drag losses with a larger vehicle. :eek3:
If ever find the time and money, I'd like to fabricate a underbody tray of aluminum or CFRP. h:
Old Mar 29, 2005 | 08:59 AM
reno96teg's Avatar
and just as useless as the non-technical threads.. :fawk:
Old Mar 29, 2005 | 10:41 AM
hakjai's Avatar
hakjai
.32 is pretty good, my 330 is .32 as well
Old Mar 29, 2005 | 12:14 PM
EvanG23's Avatar
EvanG23
Kid w/ No Money
So what all can you do to beat the drag?? I mean this would help tons with gas mileage too...
- roll up the windows
- maybe removing the rear wiper
any others??
Old Mar 29, 2005 | 12:25 PM
Epoch's Avatar
Epoch
CHRISTMASTIME IN IRAQ
I would be curious to see the CD on a jdm front end compared to the USDM front end.
And an USDM ITR body kit would also reduce the CD to .30. I would also like to know the CD modification that the GS-R spoiler does to the car, if anything at all.
Old Mar 29, 2005 | 12:58 PM
JoePoonani's Avatar
JoePoonani
Lexus Tech y0!!
thats some good info there LT :goodjob:
Old Mar 29, 2005 | 01:22 PM
Kai's Avatar
Kai
Rotorphile.
Gen 2 nonVTEC 24.47
Gen 2 VTEC 19.54
It's not physically possible for the G2 RS/LS/GS to have five square feet more frontal area then the GS-R. They where identical, plus or minus about 0.5 ft^2 for the front lip moulding.
I wish the aero kit parts didn't rust off my car... it's hovering around .30 CD right now.
Old Mar 29, 2005 | 02:34 PM
LT's Avatar
LT
more insight from oh-so-wise Tuan.
frontal area is the surface area presented to the wind or air by your hood, front cowl, front headlight assembly or fascia, intercooler if you have one or bottom part of your radiator , and yes, the front air dam.
if you lower the car, you haven't changed the surface area. you still have the same parts that are smacking up against the wind as the car goes forward.
lowering the car is mainly to help change the center of gravity's location to a better or more stable location for cornering and front to back weight transfer as you corner or accelerate in a straight line,
what is frontal area?:
Imagine if you had a brick wall and were pushing it from behind with your car.
The area (height x width) of the brick wall is what is generating resistance against the oncoming wind or air.
the wind or air smacks up against that wall surface and pushes against it. That's what is slowing you down (partially).
the smaller the brick wall, the less you have to push.
now, back to topic on the effect of lowering the car and drag resistance:
by lowering the car, you decrease the amount of air that goes underneath the car. this air travelling underneath can generate turbulence under the car and turbulence as it exits from the rear of the car by creating vortices behind the rear bumper.
turbulence adds drag.
but the lowering effect has no bearing on area. you're just making air flow over the car more rather than some getting underneath...which is in itself a good thing. You do reduce the drag a bit that way.
Those wide mouth air dams add front surface area. A lip is not a huge change in area. A lip prevents air flow from getting under the car. That's why it's good. You should read the threads here that talk about what a front air dam is supposed to do and what a rear splitter is. The front air dam works together with a rear splitter to increase downforce and reduce drag.
PS here is the article I wrote back in March 2002 about air flow control under the car for increasing downforce in a straight line
