Aerodynamic drag...our biggest enemy!
I <3 my ITR lip.
Originally Posted by So.Cal_INTEGRA
hahah i just read that thread on T-i. Who would have thought that at 90mph you lose 31.9HP with the stock bumper. Imagine how much u lose with some of those really bulky kits.
Originally Posted by Reno Fett
you're not losing 31.9hp, you're using 31.9hp just to overcome air resistance. that is, of course, assuming that that calculation is accurate, and conditions are ideal.
this is not factoring in wind, % change in humidity, etc.
Originally Posted by LT6916
scraped the SiR-G lip, eh?
:dunno: what you're talking about...I never had an SiR-G lip...I've had the ITR lip for a while now. Like the SiR-G? Sure...but they're hard to come by, and I'm not gonna pay what most people want for them.
Originally Posted by TheOtherDave™
If ever find the time and money, I'd like to fabricate a underbody tray of aluminum or CFRP.
h:
h:
Originally Posted by WackyRicky
You can make a functional under panel out of any material that is strong enough. I've read an article in a Japanese car magazine, in which they tested under panels made out of several different materials like sheet metal (aluminum, or was it stainless steel?), plastic, and even plywood and they all yield the same result (when it comes to lessening turbulence under the car). I can't remember exactly how they conducted the test tho. Anyways, with that being said, you probably want to stick with metal or CF because of heat and other stuff. (plywood will rot and you don't want to drive around with rotten pieces of wood under your car!)
From a cost-benefit standpoint, it sounds like aluminum or stainless steel sheet would be best. It will manage heat well and is easily stamped, cut or welded.
A word of caution, though: If anyone is roused to action and decides to go with aluminum, be sure to add rubber isolators between the aluminum panels and the steel chassis. You don't want electrolytic corrosion to set in.
While a CFRP undertray would look fantastic, it'd be a bitch to repair if it were to crack.
h:
