Ls Block.. With Weisco Piston...
Old Mar 17, 2005 | 05:56 AM
yangmonkee's Avatar
yangmonkee
Default Ls Block.. With Weisco Piston...
I Have A stock Bore Ls Block... And Weisco.. 11.5 To 1 Piston.. Does The Ring Come Pre Gap..??? And If Not What Is The Gap.. Size... On The Ring.. That I Have To Gap It To..?? Thanks For Looking At My Problem.... Bee
Old Mar 17, 2005 | 06:55 AM
HPIracing's Avatar
HPIracing
do you have the factory book? I forget what it is its like
top compression is .0015-.0018 or something like that
bottom compression is .0015-.0018 or something like that
and the oil control ring is a bit different i don't remember. Dont use my specs, im just guessing from my memory. You need the factory book, go to the dealer if you dont have it and make a photo copy of the page. You need feeler gauges to measure it, but make absolutely sure the gap is within spec and the rings are spaced according to the book! This is crucial!
Old Mar 17, 2005 | 03:27 PM
dubcac's Avatar
dubcac
I
You will have to gap the rings yourself.
Old Mar 17, 2005 | 06:35 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
It depends on the manufacturer of the rings but for an LS using OEM rings, the gaps should be as follows according to the service manual:
Top ring: .20-.30 mm
Second ring: .40-.55 mm
Oil Rings: .20-.45 mm
Even if they aren't OEM rings, that would probably be a good guideline to follow. Some engine rebuilders like their rings gapped to the smaller side of spec to obtain good static leakdown numbers. It is all up to you.
Old May 5, 2005 | 04:27 PM
yangmonkee's Avatar
yangmonkee
Default thanks for the info...
thank you guys.. i didnt know what was the specs but.. now i have a new question....
Old May 5, 2005 | 08:51 PM
Provocateur
On permanent hiatus
And that would be...?
Old May 6, 2005 | 02:33 PM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
Default A general gripe about post content. Ignore at your own risk :p
It Would Be Wonderful If Everyone Would Stop Experimenting With The Rules Of Capitalization. n using lettrs n #s 2 say it fastr only makes evry 1 confused. so too is punctuation because otherwise its n e 1s guess as 2 WTF u r talking about
If you'd like help, please write in a normal, understandable fashion.
Thank you.
Old May 6, 2005 | 03:06 PM
M@rshy's Avatar
M@rshy
٩(̾●̮̮̃̾•̃̾)۶
It took me a little to read it. I R Gud Reedar!
Old May 6, 2005 | 03:17 PM
TheOtherDave™
Apathy Kills
Good. My point has been made.
