camber kit
Old Mar 29, 2005 | 12:41 PM
danteisme's Avatar
danteisme
Default camber kit
well, im not sure what happened, last year i dropped my car 1.5 with tananbe springs and the guy that did my alignment said i was in spec. this year, after 4 new tires the guy says my toe is now out -2.5...dammit. so i guess now im gonna have to invest in a kit for the front. who makes a decent kit that is affordable? i know i dont wanna spend 20 bux on an ebay one, however i was on ebay and did see dropzone's front kit for 45 plus shipping i think. what do you guys suggest? i really dont want to spend more than 100 bux.
Old Mar 29, 2005 | 01:17 PM
94civicEX's Avatar
94civicEX
I got worms.
Hmm, your camber may be in spec, if your toe is out a camber kit would not effect that. This is an issue with your tie rods, not your camber.
99 Integra GSR
06 TSX
duck squad member #00003
Old Mar 29, 2005 | 01:20 PM
danteisme's Avatar
danteisme
hmm, well the guy says im out -2.5 degrees due to my springs
im assuming he meant the toe becuase my tires are out more on the bottom than on the top.
94civicEX's Avatar
94civicEX
I got worms.
If he said you had Camber, then maybe, but you said you had toe.
99 Integra GSR
06 TSX
Old Mar 29, 2005 | 01:40 PM
danteisme's Avatar
danteisme
i'll have to see what that printout he gave me said again
Old Mar 29, 2005 | 03:41 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Toe is adjustable but camber isn't. Unless of course, you purchase camber kits.
Old Mar 29, 2005 | 04:58 PM
danteisme's Avatar
danteisme
well, im not up on my suspension stuff for the teg, motor and other stuff im somewhat knowledgable. the guy told me he coudnt adjust it back into spec becuase it has fixed castors(sp?) does that help figure out if he was talkin about toe or camber?
Old Mar 29, 2005 | 05:22 PM
b00gers's Avatar
b00gers
There is caster, toe, and camber. All 3 are different. Type or take a pic of your readings.
Old Mar 29, 2005 | 05:24 PM
danteisme's Avatar
danteisme
when i get home from school this week i will type out the readings off the sheet
Old Apr 1, 2005 | 01:54 PM
danteisme's Avatar
danteisme
ok, i re read my alignment sheet, its the camber that is out -2.5 degrees. so..., who makes a decent affordable front camber kit that will fix my -2.5 degree camber?
