LS Tranny Problems: Please help
Old Mar 21, 2005 | 11:50 PM
Spec R's Avatar
Spec R
Default LS Tranny Problems: Please help
Well, to say it shortly, my tranny's (00 LS) age (115k miles) has reared its ugly head, or so i think...
here are the symptoms.
1. pops out of 2nd around 3.5k-4k rpm violently from either soft decel or accel (no consistency). it pops out sometimes even if i'm holding it in there
2. funny gear mesh whine in upper gears
3. hard downshifts 3-2, doesnt want to go in
4. excessive notchiness 1-2
5. from dead stops, right when the clutch engages, i can feel the shifter want to get out of gear, like its kicking back at me
odd part is, i do drive spiritedly, but rarely full on gear mashing. i heel-toe and revmatch almost every time i slow down, and none of the gears (including the 1-2 shift, if it doesnt pop out of 2nd gear gate) grind AT ALL.
Obviously its something to do with the synchro's, but the symptoms arent very typical of a "raced" on transmission (i.e. lots of grinding). I'm hoping its not something bigger, like a cracked input shaft, or a loose clutch/flywheel etc. Also, my linkage is straight and everything connected to it is in working order.
Setup: 00 LS with ES torque mount inserts, ACT Streetlite, ACT HDSS installed about 10k back) Prothane linkage bushings, stock shift lever.
Any hints or advice is greatly apreciated. thanks in advance.
DB Squad
Integra Forum Moderator
Old Mar 22, 2005 | 11:09 PM
Spec R's Avatar
Spec R
18 views but no answers....thanks though!
DB Squad
Old Mar 24, 2005 | 09:16 PM
SP00NFed's Avatar
SP00NFed
FuK JDM
try changing the tranny fluid and some energy suspension shifterbushings? do you have a Shortshifter?
Old Mar 24, 2005 | 10:53 PM
honura's Avatar
honura
Seni
Ehhhh it's the oil when gears pop out it's a sign of not having oil.
Old Mar 25, 2005 | 12:12 AM
Co0lDood's Avatar
Co0lDood
[ATP]ATL
when was the last time you changed your transmission fluid?
