- Any 1 know how to install/tune a BuddyClub V-con V-tec controller for a 00 civic EX?
- limits on my build...
- rough idle on my 91 accord
- h22 in to 92 civic si
- similar websites to hmotorsonline.com
- What boost pressure?
- wagon needs tune up
- gsr tranny problem
- Sleeving?
- New Engine [H22 into Integra]
- Vehicle Speed Sensor, ECU code 17
- I wanna build up my engine???
- whats the best CATALYTIC CONVERTER ?
- VTEC issues
- type r in 91 integra ls
- 95 dx hatchback engine swap
- A/c not working on 1991 accord
- rough idle on 96 civic when A/C on
- 2000 LS Engine w/ JRSC
- slight header problem, need help
- CV Axles [B18C1 into EK Civic]
- Yo Yo....
- Bizzare stalling problem, no cel code, searched like a mofo'
- shifter moves too much when in
- need help with my f series
- b16 an gsr question..
- No oil to oil filter/sensor
- 93 2 dr Integra GS to swap or not to swap
- VTEC/V-AFC Question
- does some one know a site?
- Question about Alternator Compatibility
- D16Z6 motor
- 91 Acura Integra ls/vtec setup
- New Clutch Won't Disengage
- problems with my fans
- HELP: 94 GSR crank but will not start, problem is intermittent
- Vtec Mini has problem, revin idle?
- d15a3 distributor on a b18b1 engine help ???
- concerns and need help with tranny!!!
- Turbo Cam
- honda d17a2 swap
- is royal purple a good way to go?
- 97' Honda Civic Ex engine swap
- My vortech civic w/probs
- obd conversion
- y8 head on cx block
- '93 del sol si B16 or B18 swap.
- 87 prelude si swap
- transmission housing bolts
- mini frankenstein build
- synthetic oil
- difference between hydro an cable?
- "chrome"?
- Replacing the Oil Pan in my Vehicle
- Resetting ECM after o2 sensor replacement
- b20/vtec vs ls/vtec.. what is your input?
- ls/vetc vs type r which one is faster
- What does the CEL look like?
- a question about a sensor
- 97 4-door swap suggestions
- quick h22 Q
- Recurring Dead Battery
- transmission clunks going from 1 to2 when warm only
- F20b "Bluetop"
- Timing belt
- do u have too
- B20B swap into B20a3 Prelude
- a problem i cant figure out
- Mega Squirt ems
- is there a way to tel weither your transmission is lsd or not?
- Should I keep the F, or swap for the H
- engine help!
- Honda Help with my Vtec Mini.. Simple Upgrades.
- B20V question
- Check Engine light
- I need help!!!!!!!!!!!!!!!!11
- turbo jdm h22a and other opinions wanted
- Cracked jrsc inlet.
- Totalled Integra GS
- How much HP would this set-up make?
- Swap to A2
- K24/K20Z3 combo swap
- Jet Performance V-Force Module
- Timing B-18
- AC System on Accord '03
- b18c1 w/ctr internals what do you think?
- 93 Honda Civic motor swap
- puttin in a b16a sir II motor into my 97 civic ex **help**
- gs-r tranny vs b16 tranny
- Help-1993 Acura Vigor
- A very strange swap
- 2000 civic SE - trouble codes ?
- b18c1 going into 99 Civic LX 4dr - need some help!
- b20 swap little problem
- Vtec Engages ONE TIME ONLY???? HELP?????? [CRX w/ B18C1 swap]
- 92 Int b16 did I get a good deal?? [Also w/ swap Qs]
- 02 RSX-S Knocking
- Swap suggestions??
- ZC Swap ECU problem
- swap
- Major B18 engine hang up to diagnose - please help
- will 90 integra o2 sensors work in a first gen b16a??
- Q: Stripped Crankshaft?
- help me be one of you
- tuning
- feedback on build
- PM6 Tuning
- prelude si 89 /grs
- just got a civic...need help!!!!!!!!
- RC injectors into b16???
- MAP sensor on a B16 crx?
- B18B1 Sputters ['99 motor; '96 Civic Chassis]
- Integra engine into a 94 civic?
- boost spike
- B series tranny gears
- Need some help deciding
- iat sensor
- Idle question
- arp headstuds help
- exhaust
- itr tranny in a 93 ls
- Finally started my GSR build
- Would a K20A3 fit my '97 hatch???
- Hondata S300 Update
- tanny swap
- codes and how to fix it
- Integra Engine swap! Pls Help!
- jerky acceleration
- loud noise need help!
- Ecu and harness...
- tranny slipping
- 90 DA to obd1.. is this possible
- JDM or USDM (ecu and harness)???
- Clearence
- ls/vtec piston ring choice?
- Q: aggressive cams with stock valve train
- turbo b16 not lookin good!!!please help!
- 95 turbo'd d15 cam timing ?'s
- fuel pressure in eg w/gsr
- another nitrous Question
- V-tech?
- wanting to be loud and proud|school me
- h22a question [How to ID a JDM motor?]
- a_integra_87's turbo install thread!
- 92 4 Door Accord Problems
- how reliable is this????
- 93 civic si won't start
- um can i do this??
- Ls? [Integra; B18C5 swap]
- Need Help On Wiring For Swap(website,or Manual).!!! H22 Into 96 Ex!!!
- H22a wiring help
- swap a B18a for a D15b in a 90 [Integra]? Will this work?
- h22a not starting
- Cam Degreeing on Vtec
- axels
- Question about the '95 Accord
- Pa People
- B18c questions
- what header dose he use
- Top end
- which arp main studs?
- help me guys can you tell whats casing this
- Which Engine/suggestions swap
- 1996 Honda Civic DX dieing
- awww. f series
- H23A1 Calibration?
- 5th Gear Pop out Problem... HELP!
- What motor should i use for my car
- Having boost problems! Need help!
- 86 escort pony
- My New Setup
- Tuning??
- B16A2: Must I have ECM Connector A??
- nitrous question
- exhaust question
- whats a good turbo muffler???
- HELP!!! D16Y8 Problem
- Harness Question
- Electrical Fan Problem????
- b16 trans into a 1992 hatch with LS swap??
- Main/rod bearing size choice HELP?!?!
- HELP!! Civic Starter and Alternator
- more power?????????? [Civic / B-series Hybrid]
- more power ??????
- radiator
- installing piston rings?
- emoving wrist pin?
- suspension question, no where else to put this
- 1995 zchaed
- Help!!!!
- OBD II DLC Locator
- 1994 accord into 1991 integra ? Yes or no
- Misfire???
- which valves and cams for N/A build?
- Help, b16a won't quit
- sohc vtech/d15 trans
- stroker motor
- hi
- ??keeping my power steering and a/c
- 96 Civic Hatchback CX
- Starting a swap
- Help with SBCi-Blitz Boost Controller
- idle problem
- exhaust help
- Car Electrical Experts Please Help!!!!
- b20 head onto a b18b1 block?
- boost with nitrous
- P30s into an LS?
- help please
- Checking main bearing clearance?
- My RSX Type-S Hondata tuned dyno
- Ignition Components
- Jumping Tach
- b16a pistons?
- thicker thicker pistons [B18C into DA Integra]
- ls/vtec build piston choice
- Terrible electric problem
- 00ek wiring jdmb8ci
- 01 gsr stalling at idle
- anyone bought a turbo from..
- hello I NEED HELP
- Trany issues
- Trany issues
- Just A Question
- ls/vtec build questions
- 5 wire to 4 wire
- How to change a 5 WIRE O2 SENOSR TO A 4
- hi i need help????
- Hey check this out!
- Gsr Swap
- My po6 ecu
- New Motor...b20b?b18c? [DC Integra chassis]
- crx supercharge question
- What I did and what i plan to do, intake manifold/T Body
- h22 swap [into 1990 Integra]
- I need a bit of advice....
- Help!
- b18c1 in 94 civic si.. with obd2
- what header is the best for my 88 jdm zc
- P28 Ecu..
- mini-me d16z6 head storage & prep questions
- CryO2
- F20B Parts
- buliding lsvtec motor
- How to tune to increase starting speed
- Wtf
- D16Y8 on JDM EG6 Questions and Doubts
- does this crap ever stop?
- boosted 2000 si
- 2000 civic si tranny
