Sleeving?
Old Sep 10, 2006 | 07:44 PM
SiAm06's Avatar
SiAm06
Default Sleeving?
Now how exactly does the sleeving go down.........i kno that they are thicker and lets say you buy it for a b20 specifically 84mm block......now does that interfere with the size pistons application. Do you still use 84mm pistons or do you have to bore and then keep same size pistons for the fitment or what. How exactly does sleeving work.......cuz from what ive seen which was a close decked sleeve block.....it changed the whole complexion of the internals.
Old Sep 11, 2006 | 06:58 AM
Provocateur's Avatar
Provocateur
On permanent hiatus
84mm sleeves will use 84mm pistons.
Old Sep 11, 2006 | 01:18 PM
Snoopy's Avatar
Snoopy
been there done that
you bore the sleeves to the size of the pistons you'll be using
