Resetting ECM after o2 sensor replacement
Old Aug 31, 2006 | 09:29 PM
zz28zz's Avatar
zz28zz
Default Resetting ECM after o2 sensor replacement
How do I reset the ecm after I replace an o2 sensor that was giving a code 41? Do I have to use a scanner?
Old Aug 31, 2006 | 09:38 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Just unplug the negative terminal of the battery. Make sure you have your radio code available before you do so.
Old Sep 14, 2006 | 05:13 PM
zz28zz's Avatar
zz28zz
I got the auto parts store guy to reset the code with a scanner. So that's fine now.
My batt is getting weak however, so it won't be long before I have to replace it. How do I find out what the radio code is?
