Gsr Swap
Old Jul 2, 2006 | 02:16 PM
95LSv's Avatar
95LSv
Banded
Default Gsr Swap
I plan on swapping a GSR motor in my 96 ek hatch. I was wondering on what a reasonable gsr motor would go for. Plz help me out, just so i don't get ripped off.
Old Jul 3, 2006 | 09:49 AM
hitman619's Avatar
hitman619
SDSU Basketball
usdm about 3000.00 engine tranny.
jdm about 2800... engine tranny.
i see you live in cali so jdm is out!
check your local honda acura junkyard for prices...
my gsr swap ran $3300.00..... 3000.00 for the engine and 300 for the labor and gsr brake upgrade....
"honda acura parts" in chula vista CA, hook me up.....
talk to jesus...
Old Jul 3, 2006 | 06:43 PM
95LSv's Avatar
95LSv
Banded
Oh ok, thanx man... My friend wants to sell me his usdm for 2700, i think he just rebuilt everything, so i guess I'll get it because it sounds like a good deal. Thanx
Old Jul 21, 2006 | 08:47 AM
tommyhcky13's Avatar
tommyhcky13
it's definately worth the money
Old Jul 24, 2006 | 01:26 AM
xsuperxsonx's Avatar
xsuperxsonx
Default ...
First things first ... Going GSR b18c/1 your going to need the following parts .
-gsr throttle cable (usually purchase the year of the motor)
-aftermarket motor mounts (if you plan on being cheap and going with oem mounts you will then need the following)
- 99-00 si top transmission bracket
- 99-00 si rear t bracket
- 99-00 si motor bracket (it has two studs comming up , bolted to the b16a2 block)
- 99-00 si complete driverside mount
(since your EK is a 96 , its best to find a 96-98 civic ex engine harness)(unless you plan on going cheap and just using your stock nonvtec harness and splicing and rewiring vtec+knock)
Im pretty sure you can purchase a complete swap for a affordable price, Im from Texas and swaps down here go 1,800$ complete (axles,shiftlinkage,ecu,engineharness,etc...)
Let me know how it goes , you can also shop around local websites www.honda-tech.com , www.ebay.com .... GOOD LUCK
