crx supercharge question
Old Jun 30, 2006 | 11:25 PM
dapump2003's Avatar
dapump2003
Default crx supercharge question
i jus finish superchargering my d16a6 .. it run fine but the only thing is that it squeak really loud.. could it be my alternator belt is worn out? any info would be great.. the supercharger is set at 6 psi but i am only getting 4 psi..
Old Jul 2, 2006 | 09:31 AM
AccordVT's Avatar
AccordVT
Ian
They do squeel pretty bad but i'm sure you knew that. Check for an old idler or bad belts as you siad.
Old Jul 9, 2006 | 04:29 AM
daveb91's Avatar
daveb91
Boo Boo Kitty F*#k
Did you tighten the belt? You have to make sure the idlers are a little loose then tighten it down. Make sure you retighten the idlers. With my stock pulley setup I was almost out of adjustment with the tightener screw.
