Finally started my GSR build
Old Aug 10, 2006 | 07:06 PM
dmacaalay's Avatar
dmacaalay
Monkey See, Monkey Do!
Default Finally started my GSR build
After months of having my gsr motor pulled (11 to be exact), I finally got around to rebuilding it for an all motor set-up. Thanks to all the previous threads on building up their GSR's, it helped me decide how I want to build it and what power to expect out of it.
Here is what I have so far:
GSR Block with..
JDM ITR Pistons on GSR Rods
OEM Piston Rings
King Bearings
All new oem gaskets and seals
OBD2 GSR Head with..
ITR Cams
AEM Cam Gears
Skunk2 Valvesprings & Retainers
Supertech Racing Valves
Skunk2 IM w/Hondata Gasket
ITR Throttle Body (port-matched to IM)
AEM Fuel Rail & FPR
B16 Hydro Tranny
ACT 6puck Clutch
That is it for now.. Still deciding on which header and intake. I keep running into $$$ issues. Why can't I just be sponsored already!!
Old Aug 11, 2006 | 12:43 AM
Provocateur's Avatar
Provocateur
On permanent hiatus
I would use the proper clearanced OEM bearings instead. What kind of fuel management are you going to be using?
Old Aug 11, 2006 | 03:32 AM
dmacaalay's Avatar
dmacaalay
Yeah I was kind of hesitant at first when using the King bearings, but all the clearances were within spec when I measured them so I figured I'd give them a shot. As far as engine management, I have a p28 with obd2-0bd1 jumper, but I'm still deciding on Crome vs. Hondata.
Old Aug 11, 2006 | 10:29 AM
mberndt's Avatar
mberndt
IMO I always say to use genuine Honda parts when you can...
But, if you measured the specs, then I'm sure you're good to go...
As for the tuning, I would have to say Crome, hell it's FREE!
That outta be good enough in my book
I know the Hondata's are nice, but for $600... I like the sound of FREE
Otherwise sounds like a nice setup...
Good luck man
Old Aug 11, 2006 | 11:17 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
Regarding bearings, I went with Honda OEM on my first build (~290whp, ~13psi) and then went with ACL on my second (457whp, 23psi). As mentioned, as long as they're spec'd/clearanced properly then you're set. I wouldn't even just drop OEM bearings in either, I'd spec anything that you decide on, to be safe. Nothing like a bearing set that's too tight or too loose on a crank journal. :hs:
GL dude!
Old Aug 11, 2006 | 01:59 PM
Snoopy's Avatar
Snoopy
been there done that
if you have the money to spend and want a great header, look into smsp or rmf. they both have great headers in the $700-$800 range.
Old Aug 11, 2006 | 05:36 PM
Provocateur
On permanent hiatus
It isn't free. After all the hardware to get it to function just like Hondata S300, it will be cheaper, but no where near free. And if you want datalogging, you will have to fork out $175 for Crome Pro.
And Hondata S300 can be had cheaper than $600.
Old Aug 13, 2006 | 10:26 PM
dmacaalay's Avatar
dmacaalay
Default tuners??
anyone know of some really good tuners out in the bay area california area?? i know how to build motors and everything, but i have no clue when it comes to tuning them.. im leaning more towards crome..
Old Aug 13, 2006 | 10:53 PM
dmacaalay's Avatar
dmacaalay
BTW, just got back from RENO.. got me some more money for my build!! :irock:
Old Aug 14, 2006 | 08:52 AM
Snoopy's Avatar
Snoopy
there's dynospot racing in san jose and dnr in hayward
