Harness Question
Old Jul 22, 2006 | 10:23 AM
ricunger's Avatar
ricunger
Default Harness Question
i have a 97 civic ex auto and a b16a2 from a 99 si can i use my ex auto harness or do i need one from a obd2a 5sp ex?
Old Jul 28, 2006 | 06:16 AM
flappy188's Avatar
flappy188
O.G. SON!
you can use your existing harness, but you will have to add wires for v-tec sol, v-tec pressure switch, knock sensor. good luck man
Old Jul 28, 2006 | 07:51 AM
Andy's Avatar
Andy
Hybrid Forum Moderator
You will need to use the '99-'00 Si harness. The ECU plugs changed slightly (I don't know if just in wire location or physical design) and are sometimes refereed to as OBD-IIa and OBD-IIb. Since you will need to an OBD-IIb Si ECU, you will need the OBD-IIB harness to plug into it.
On the '96+ Civics, the wiring harness connects to the ECU, passes through the firewall on the passanger side and goes directly to the engine ('92-'95 Civic's and '94+ Integra's had a sepearte engine and in-car harnesses). Assuming the engine comes with a complete harness, just leave it on the engine and use that. I believe there are some issues with the 2 being somewhat different (something with an gas tank pressure sensor the '96-'98 Civic's don't have) but I don't know all the specifics as I've never done that swap. I also don't know what kind of issues you will run into with the automatic changeover concerning the wiring differences.
