How to tune to increase starting speed
Get a lightweight flywheel.
Depends on your budget and goals. You've just got to modify the car. You can make it lighter, make the engine's internals and everything dragging on it lighter, you can put more air, fuel, and spark into it and take more exhaust out of it and change the time and duration that everything happens and you'll get more power or the illusion there-of. Assuming of course everything's done right. Otherwise things might actually slow you down or blow up.
Is it true that if you add more torque then it will simultaneously decrease acceleration? I heard people compare torque and acceleration as a balance equation that they are equivalent at a fixed point when a car first comes out stock. When one side is weighted more, something from the other side must be taken away.
Also, how exactly does an intake help to improve performance?
intake improves performance by allowing a higher airflow, getting rid of a certain amount of turbulance to help the venturi effect (although it's said it doesn't matter in the intake, it's the intake manifold that that really happens), and to cool incoming air because cooler air carrys more oxygen.
(because torque is a function of horsepower relative to RPM... I don't understand that concept 100% but I know that it exists...),
Horsepower is a function of torque. Torque is measured, horsepower is calculated.
HP = (TQ * RPM)/5252
