HELP: 94 GSR crank but will not start, problem is intermittent
Old Sep 4, 2006 | 11:47 PM
nonbox's Avatar
nonbox
Default HELP: 94 GSR crank but will not start, problem is intermittent
I have a 94 GSR with 110,000 miles on it.
PROBLEM: It starts in the morning. After I drive it, shut down the engine, do some errands, and then restart it, it will not start. It will crank but will not start. When I wait a few minutes, then turn the key it will start. This problem is intermittent. It sounds like the main rely but I changed that last year.
When I turn the key to the number 2 position, I do hear the fuel pump priming.
I have changed:
spark plugs, ignition wires, coil, ignitor, distributor cap and rotor, main rely, and battery (new).
I have NOT changed:
altenator, starter
Is it the altenator or starter? Is there a way to check these without taking them out and bringing them to a auto store to test?
Old Sep 6, 2006 | 11:30 AM
mberndt's Avatar
mberndt
It's not main relay or else you wouldn't get it to turn over or even hear the fuel pump prime...
Alternator just charges the battery, car drives off of battery... then when battery dies, car dies, so no it's not alternator...
It's not starter, cause if it's cranking then the starter is obviously good.
I would check ignition connections, also check for a loose ground... I had a misfire problem for 2 months, and had replaced everything like you did, but in the end it was a simple loose ground that would cause the car to misfire ONLY WHEN HOT, which leads me to believe that your car has a similiar issue, as you say it doesn't start after it's used for errands (and it's up to operating temp).
Pop your hood at night and have someone else start the car, look for any sparks, that is how we found my problem...
Hope this helps, good luck!
Old Sep 12, 2006 | 12:38 AM
nonbox's Avatar
nonbox
What are the symptoms of a starter going bad?
Old Sep 16, 2006 | 07:42 PM
nonbox's Avatar
nonbox
The problem has not reoccured in 2 - 3 weeks.
