Timing B-18
Old Aug 26, 2006 | 04:42 PM
docglen909's Avatar
docglen909
Default Timing B-18
Small Problem, just wanted to know the best way to set the timing on my engine, Timing belt broke so I got a new head belt and everything else to do it. Thanks....
Old Aug 26, 2006 | 06:35 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Line up the TDC mark on the crank with the mark on the lower timing belt cover, set the cams both to TDC, slip the belt on, and tension.
Here is a writeup: http://www.team-integra.net/sections...ArticleID=1044
If your belt snapped, chances are you bent valves since the B18 is an interference engine. You really need to remove the head and check for any bent valves before you replace the timing belt.
Old Aug 26, 2006 | 07:58 PM
sherwood's Avatar
sherwood
I missed Sean
http://www.c-speedracing.com/howto/timingbelt/tbelt.php
theres another write-up for you
Old Aug 27, 2006 | 06:26 AM
docglen909's Avatar
docglen909
Thanks alot guy's for the info. The valves are bent but I already knew that, I bought new valves and head kit.
