- how to to change from automaic to 5 speed
- help me please!!!!
- Integra meet UK in the south
- how to remove rear windshield wiper motor cover ?
- Any one has these wheel on their car? Work Emotion Kai
- how do i switch BOV
- vtech controller
- I Got My Car Back
- What would be more useful?
- Righty Losey Lefty Tighty ???
- smog question
- oem antenna replacement
- headers question?
- GSR requires 91 octane, we only have 87,89,93,94 octanes
- How Should I Tune A 90 Teg
- Stabilizer bar end links?
- vtec does not pull hard any more why?
- Headlight Adjustment Question
- O2 sensor Q?
- Drivers window rattles...cant fix?
- How to pull codes on a 12/94' Integra?
- ITR price
- Anyone with sunroof problem? Needs to manually push it up to get it going
- New front axles, now a new noise
- DH-Racing?
- quick question about checking CEL's
- $888 to fix my A/C
- My Bad Need Help
- My Bad But I Need Help
- July BBQ in NYC !!!
- bulb part number for dash gear indicator
- gonna need a cleaning supply expert on this one. =P
- rear wiper
- help? what to do to my integra
- h-brace
- UPDATED!!! really thinking about getting this
- RSX seats in a teg?
- Gs.. Ls.. Rs... Gs-r ???????
- Lower balljoint problems
- Gsr cams or B16
- question
- need new tie rods, what's a good brand?
- really thinking about getting this
- ls/vtec trouble
- Swap problems
- are these springs and retainers good enough?
- Need help modding 1996 Integra
- headlight question
- advice needed - shifting becoming difficult
- Is the Greddy SP2 legal for use in CA?
- my turbo gsr is totaled
- cold air extension
- Tires
- ???? For Type R owners
- Does anyone ?????
- Gsr
- Few problems I need help with 90 integra
- Hype-R-Fest Event in Virginia July 15th/16th/17th
- relay questions
- Turbo-ing an Integra.
- brake booster?
- oil leak
- And Now To Make Myself Sad
- • Integra Forum Policies [Read Before Posting]
- Tires
- gsr engine very slow
- Need help installing Volt Meter Gauge...
- Front upper strut bar?
- Virgin at mods
- Need Help To Check Carfax
- looking for new thermostat
- Just got my new clutch and flywheel
- honda integra?
- need help with acronyms
- 90-93 Integra Needed In So Cal!!!
- Where's my O2 sensor?
- Lightbulb Queston from nOOb
- Short Shifter, same for G2 and G3? (+ another Q)
- bubble in my tire
- Should I buy this 95 integra
- O2 sensor
- JDM HID Question
- need carfax on 04 tl
- PWO Ecu
- kosei k1's ok for normal street use?
- no muffler
- ac condenser problem?
- Ls/vtec List
- Omni Power or Skunk2 coilovers??
- car is bogging after replacing ECU
- major problems help please
- is my alternator shot?
- Acura Integra '94 Auto Transmission Problem
- Wiper problem
- integra fans arent workin
- ITR tire purchasing Questions
- touch up paint for 98 ITR
- Seat belt problems?
- Difference in gsr clusters
- Arc Induction Box for DC2
- MAP trouble
- Which engine.
- 1998 USDM ITR headlights Q
- Car wont start
- Hood scoop for something other than intake??
- Where to find replacement body panels?
- 97 alarm troubles
- swap question
- Changing final drive in 2nd gen
- Comfortable Springs / Struts
- Painting 94-97 Tails
- new owner, first questions.
- seatbelt buckle???
- Is there a difference between the Apexi WS & WS2?
- Whatdoyoucallit????
- Is my main relay gone?
- MY abs light is on- help
- Urethane Sway Bar Bushings = Low Cost Car Control
- integra 94 vs accord 95-97 ex...??
- My RPM is at 5 THOUSAND?
- tranmission fluid
- Tom's Motorsport Exhaust?
- My car wont start sometimes......
- Bodywork?
- Suspension interchanging ?
- IAT sensor
- greasing throw out bearing
- Fuel Consumption
- exhaust questttion plaese heeelp
- My car over heated, now repaired... have I done anything wrong?
- Turbo?
- Air filter for '94 Integra LS
- need sum specs
- clutch question
- Old teg body panels?
- transmission malfunction
- 2001 GSR, looking at upgrades, need some suggestions
- just ordered my new rotors and pads! :yay:
- Gauges Problem
- a/c PSI?
- camber
- gauges
- muffler <MERGED>
- Acura RSX Concept-R
- Hey I HAVE 2 ???????
- trunk wont open...need help
- Cant get interior lights on!!!
- ws2 exhaust
- Weight Loss
- Wheel weight - How much is too much?
- Back in the seat again - let's hope I can keep it on the road this time...
- GSR Issues
- Finding a short or defective circuit?
- Gauge for 1992 integra
- 1994 Integra Stick Shift Sticking
- idle high then low
- GS-R is this a good deal?
- Sun Visor is too loose to stay up
- compression?
- Integra Modification Information!
- Is this a good deal?
- RPM chip
- Removing Cruise Control
- Freeze-12 experience, anyone?
- 94 integra park brake won't hold?
- seat removal
- Replacing stock headlights with new stock pair
- Ring problems??
- boring it out?
- turbo is boging help
- Please help me lower my 60' time :(
- vtec dependent headlight
- My rear doesn't ????
- car wont start
- 1995 GSR No Start - Help Please!
- servicing the car at 35 000 km
- Expert advice needed on header and exhaust
- Exhaust question?
- Guess the new mod
- New Rota slipstream sizes
- are the fuel injector in the ls same as gsr ?
- Need advice!
- Removing Emblems and Badge
- integra gsr tire question?
- 90 integ distributor problem
- swap ecu!!
- help with problem please???
- Mirrors: Difference between 94-97 and 98+
- Axxis ultimates or PBR ulimates? please help
- SRS light
- easily adjustable shocks?
- "Dinged" Header
- anyone know where to find good deals on 98+ taillights for a 99 gsr coupe??
- I suck at diy (need shock help)
- 1991 - electronic seat belt won't retract
- help: installing a new 1991 integra fog light
- Magnaflow
- My STOCK 'Teg -- why's everyone trying to race me (rant)?
- idle drops too low when car is warm
- Candied taillights
- Modding under the hood
- Big Brake clearance question
- Who can name this thingy?
- vinyl trim
- A/C Died...Help Needed!
- air intake tempature sensor
- HELP!!! Fuel Guage Reading Incorrectly
- Integra performance help
- Turbo Timer Questions
- why does my gas mileage = teh suck?
- What LCA's will fit my GSR?
- 15" Fat Five wheels?????????
- badges
- Type R sway bar on my LS
- ebay short throw shifters
- Time to sell?
- A/C Compressor/clutch replacement?
- coilovers r good or bad?
- b18b or b18c???
- Passenger Hump
- Checking the motor mounts
- rjs harness
- integra 91 3 cylinder running please help!!
- Spark Plug wire question...
- i am so pissed
- VIDEO ...short clip of teg with gsr/b20
- where?
- best year of integra?
- rsx tranny in integra?
- ITR Expo 5 Was a blast!
- Vtec Controller
- EL springs and the teg....?
- guys help plz
- integra or prelude (all Out)
- JDM ITR cluster gauge problems
- gsr strut tower bar, bolt's part number ?
- Teg vs DSM
- o2 sensor and engine identification
- B18C1 - is mine a OBD1 or OBD2
- 86 teg engine code?
- locate fuel pump relay in 1990 integra
- motorsport shops in socal
- Suspension problems?
- Pick up (gear shift) is slow
- Cracked radiator
- New Member, new (used) integra
- strange tapping
- How much sould I sell for?
- Driver Window Removal
- Car shakes when switching gears (A/T), advice?
