Which engine.
Old Jun 14, 2005 | 03:51 PM
omega's Avatar
omega
Default Which engine.
I'm thinking of getting an Integra, and I was wondering which model is easier to turbo. Should I get the LS or go spend the extra cash for the GS-R, both of them '95. Just need peoples opinions on which engine is more flexible and if the extra cash is worth it for the VTEC.
Old Jun 14, 2005 | 04:33 PM
honura's Avatar
honura
Seni
Hell yes the extra cash is worth it man!!!!!!!!!!!
Old Jun 14, 2005 | 05:16 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Boost + vtec > boost
Shell out the extra money for the GSR, you will be glad you did.
Old Jun 14, 2005 | 05:53 PM
SP00NFed's Avatar
SP00NFed
FuK JDM
the extra time/money is worth getting a gsr
Old Jun 14, 2005 | 07:46 PM
FooD2000's Avatar
FooD2000
Still Water
yep, I've owned an ls / gsr, The gsr is hands down alot more fun.
Old Jun 14, 2005 | 07:55 PM
shabacash's Avatar
shabacash
I'M SO JDM, I HAVE SARS
gsr pwns ls
although i have heard good things about boosted LSs. However the extra HP with a gsr engine - i think is worth the dollar.
Old Jun 14, 2005 | 08:23 PM
flatliner's Avatar
flatliner
Fix It
just do the ls/vtec head swap.
Old Jun 14, 2005 | 09:01 PM
Provocateur
On permanent hiatus
Why? So you can have an unreliable, low revving GSR motor? With the amount of money involved in properly building up an LS/VTEC conversion, you might as well shell out the money for the GSR.
Old Jun 15, 2005 | 07:51 AM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
A stock GSR head is going to flow better than a stock RS/LS/GS head.
The GSR has a higher redline than the RS/LS/GS motor.
Both of these factors combine to make the GSR more efficient than the non-VTEC motors at a fixed boost level.
So if all you plan to do is build a decent streetable setup without going inside the motor.. go with the GSR.
But if you plan on tearing down the motor to build for a high-boost (12 psi+) build..then an non-VTEC Integra will do fine. The money saved by going with a DC4 can go into headwork and cams that will address the inefficiencies of the stock LS head.
Old Jun 15, 2005 | 12:52 PM
nguyenj82's Avatar
nguyenj82
Ls
