oem antenna replacement
Old Jun 21, 2005 | 07:08 PM
coletc's Avatar
coletc
Default oem antenna replacement
I've removed my factory antenna because it is not working correctly. I need to get a new one, and I want a "stock" - looking antenna. My #1 goal is ease of installation, so I want one that is as close to oem as possible. My 2nd goal is to not pay $230 - $300 for one of these. I want a fair deal.
Anyone have anyone I can call? Anybody got any links or websites to help me find one?
Any/all help is appreciated.
Thanks,
Tom
Old Jun 21, 2005 | 08:13 PM
SP00NFed's Avatar
SP00NFed
FuK JDM
maybe the junk yard or off ebay...the s2k antenna really doesn't look bad on the integra either but i understand you wanting to stay with the oem atenna at the same time
Old Jun 21, 2005 | 08:27 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
I just purchased the OEM mast and installed it. If you can hear the motor whirring when the radio is turned on and off, chances are your motor is fine, you just need a new mast. The ones off ebay work wonderfully and are about $15 for a new mast.
To install it, just remove that metal thing holding the assembly on, pull the old mast out with the radio on, and then put the new one in and turn the radio off. Make sure the teeth are facing toward the back of the car when you put it in. Put the metal thingy back on and you are set.
Old Jun 22, 2005 | 09:09 AM
Lsvtec503's Avatar
Lsvtec503
Unless you have luck like mine and every minor job ends up being a little more complicated then it should have been. I had part of the strip break off in the motor, then you get to take the antenna motor out, take off the cover and remove the broken piece before installing the new mast.
Old Jun 22, 2005 | 04:09 PM
DiAbLo3785's Avatar
DiAbLo3785
Working on project CRX Si
just pull out the carpeting on the side of the antenna and use common sense to figure out what to take out. its a pretty straight foward job that requires little skill
Old Jun 22, 2005 | 04:47 PM
Provocateur
On permanent hiatus
You don't even need to open the trunk to replace the mast.
The motor is a completely different story...
Old Jun 22, 2005 | 04:58 PM
DiAbLo3785's Avatar
DiAbLo3785
woops, my bad. i was just reading through not really paying attention to much so i assumed he wanted the whole thing including the motor taken off. both the images on the bottom should explain what you should do
File Type: jpg
File Type: jpg
Old Jun 22, 2005 | 08:17 PM
trextegra's Avatar
trextegra
97 Acura Integra LS 3DR
look on ebay ive seen em cheap on their juz put for the search honda acura oem power antenna
Old Jun 23, 2005 | 02:54 AM
psg-1's Avatar
psg-1
that is one hot color blue ^^^
Old Jun 24, 2005 | 05:54 PM
Integral's Avatar
Integral
Nightmare Motorsports
My car is a similar blue... well not really, but its blue ;p
I was also thinking of buying the s2k antenna for my teg...
