turbo is boging help
Old Jun 8, 2005 | 07:02 AM
92teg's Avatar
92teg
Default turbo is boging help
Help. I was on my way to work today and half way there I had put my car in boost. Instead of pulling harder my car started to bog down. Am I not getting fuel? Any information will help me out.
thanks
Old Jun 8, 2005 | 07:10 AM
civicandtegra's Avatar
civicandtegra
have u upgraded your fuel system, alot of people forget to do that
Old Jun 8, 2005 | 08:05 AM
92teg's Avatar
92teg
As of now I am running an FMU 12:1. I’m only pushing 5 PSI’s till I get a Hondata and 450 injectors.
Old Jun 8, 2005 | 08:57 AM
VTEC-Power's Avatar
VTEC-Power
God help you a FMU :doh:
Old Jun 8, 2005 | 11:22 AM
92teg's Avatar
92teg
ummm... yea thanks for the help o.0
Old Jun 8, 2005 | 11:27 AM
Provocateur's Avatar
Provocateur
On permanent hiatus
The FMU and stock injectors are probably doing it. You really need to upgrade the fuel system.
It is definitely a fuel issue and my guess is that you are running overly rich under boost with the FMU and that is causing the bogging.
Old Jun 8, 2005 | 01:01 PM
92teg's Avatar
92teg
What do you recommend Shmoo?
Old Jun 8, 2005 | 03:56 PM
Provocateur
On permanent hiatus
I recommend some tunable engine management with larger injectors and a larger volume fuel pump. Anything you choose will be a step up but ideally, you want to go with either Hondata, uberdata, chrome, etc with some 440cc injectors and a 255lph fuel pump. It isn't cheap but it will allow a larger amount of boost to be run safely without any bogging.
It just occurred to me, but you may want to also check your ignition timing to make sure it is set to factory spec.
I also assume you have a CEL with your current setup, so that may also explain the loss of power.
Old Jun 8, 2005 | 05:51 PM
92teg's Avatar
92teg
im looking at gettting a Hondata, and the injectors really soon, i have the fuel pump.
cool thanks for the help shmoo
Old Jun 8, 2005 | 06:38 PM
SP00NFed's Avatar
SP00NFed
FuK JDM
i hate this but....NA :thumbup:
