easily adjustable shocks?
Old Jun 6, 2005 | 04:10 AM
bnuk's Avatar
bnuk
Default easily adjustable shocks?
ok I'm looking at geting a spring/shock combo. I'm basicly looking for something that would be pretty decent in autocross, yet be livable as a daily driver. Here's what i was thinking: if i get an easily adjustble ride hight i can drop it 1.5"-1.75" when I get to the track and that will also give me 1 degree or so of negative camber which will be nice for autocross and then i can raise it up a little on the street so i don't eat through tires and bottom out all the time (western PA). Is there any spring/shocks that easily adjustable enough to make this idea practical? I will be changing wheels for autocross so I will have the wheels off.
Old Jun 6, 2005 | 04:17 AM
shabacash's Avatar
shabacash
I'M SO JDM, I HAVE SARS
coilovers is the way to go - most run around the same price (tein/dc2/omni/skunk2). by easy, what exactly do u mean? someting u can do without breaking sweat ? (if ur skinny, and weak like me - good luck)
Old Jun 6, 2005 | 08:04 AM
bnuk's Avatar
bnuk
by easy I mean with the front (or rear) of the car off the ground on a heavy duty jack I want to be able to adjust them (without having to use jack stands) in about as much time as it takes to change the wheels. I don't really care if its hard it just needs to be a design that is durable enough to last while being adjusted once or twice a week.
Old Jun 6, 2005 | 08:25 AM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
Then I'd recommend a threaded body coilover like the TEIN Super Street Damper System... If used in conjunction with a upgraded anti-roll bars and a camber kit, you're set.
